Best Place to buy a CV Shaft - Club700XX - Honda TRX700XX Forum
post #1 of 6 Old 08-12-2011, 12:37 PM Thread Starter
I'm going to be replacing my CV Shaft since it's started popping. My local dealer wants $206 for one shaft. Does that sound right? High? Low?
Are there any upgrades?
TIA!
post #2 of 6 Old 08-12-2011, 01:50 PM
So what exactly are you replacing? The axle shaft or a CV joint? I am guessing the $205 price from your dealer is what Honda calls the "shaft set", includes the shaft, outer CV joint, and some other small parts is what it looks like on the parts fishe:
http://www.servicehondapsn.com/fiche...008&fveh=20221
Service Honda's price is $149 for the same set. Doesn't look like you can buy just the shaft on its own.
Doug
2004 TRX450R, 2008 TRX700XX
2005 TRX450R
1986 TRX250R
D Bergstrom is offline
post #3 of 6 Old 08-15-2011, 12:35 PM Thread Starter
Well the CV Joint is popping. I was just going to replace the whole shaft. I've talked to gorilla axles and at first they'd never heard of a 700xx but now i've intrigued them. Hopefully they can build one with stronger CV's or maybe a Honda 420 or 680 rincon shaft would work the same.
I'm looking for the whole thing.
post #4 of 6 Old 08-15-2011, 01:51 PM
The "shaft set" from Honda is just the axle shaft itself and the outboard joint, would still need to get the inner joint to get a complete setup. The sprocket side inner is $170, while the other is $120. After looking at these prices, I hope I never have to replace these parts on either of my 700XX's!
Doug
2005 TRX450R
1986 TRX250R
post #5 of 6 Old 08-15-2011, 01:53 PM Thread Starter
Is it possible to just buy the outer joints? I'm sure nothing is wrong with my shafts.
post #6 of 6 Old 08-15-2011, 07:07 PM
Doesn't look like it, there is not a part number listed for just the outer joint anyway.
Doug
2005 TRX450R
1986 TRX250R
