Engine Noise - Club700XX - Honda TRX700XX Forum
post #1 of 9 Old 08-22-2011, 10:46 PM Thread Starter
Engine Noise
Just picked up my 700xx and I hear what sounds like a valve clearance issue, but not sure if it's that or the actual sound the motor should make. Anyone with knowledge please let me know..
Skinner700xx is offline
post #2 of 9 Old 08-22-2011, 11:16 PM
Probably valves needs adjusted. Is it a ticking sound coming from the top of the motor? How many hours on the bike?
post #3 of 9 Old 08-22-2011, 11:29 PM Thread Starter
maybe 10 hours on bike.. it's a small ticking sound but nothing really loud..
post #4 of 9 Old 08-23-2011, 10:14 AM
probaly just regular motor noise with them low hours.
post #5 of 9 Old 08-23-2011, 10:25 AM
I would keep an ear on it. These are known to be noisy. If it gets worse, I'd def check your valves. But for example, with my build, if I didn't hear anything, I'd be introuble. But I have different rockers and everything. So I would say you'd be okay, just be sure it doesn't get worse.
post #6 of 9 Old 08-23-2011, 10:38 AM
Skinner700XX,
Yes, as was mentioned, these engines are noisy. I was worried about that at the beginning then I noticed that when my helmet was on it was really quiet.
Get some more hours on it then when you get the first service it would be a good time to check the valves.
post #7 of 9 Old 08-23-2011, 06:12 PM Thread Starter
Thanks for the help..
post #8 of 9 Old 08-23-2011, 07:41 PM
BuckeyeXX's Avatar
You should try synthetic oil to try and quite it down. I myself just started running mobil 1 racing 4T and seemed to make a noticeable difference in the sound and shifting.
08 700XX Black/Gray
01 90 Yerf Dog
BuckeyeXX is offline
post #9 of 9 Old 08-24-2011, 10:59 PM Thread Starter
I just put synthetic oil in along with a K&N Filter.. From videos i have watched and others i have talked to, it must be the normal sound of the bike.. I'll stay on top of it and if it gets louder I'll have the valves checked.. Thanks for the help..
