I Want More Power - Club700XX - Honda TRX700XX Forum
post #1 of 29 Old 08-23-2011, 08:58 PM Thread Starter
I Want More Power
I got EHS's Big 3.
Whats next. Small increments please. Don't wanna do A B C D all at the same time and it be 2g's.
I keep seeing threads on Hot Cams and +3 TB's.
Is that next?
fhibbs12 is offline
post #2 of 29 Old 08-23-2011, 09:36 PM
A friend of mine has the big three as well and the stage three hotcam made a significant difference with the power increase.
post #3 of 29 Old 08-23-2011, 09:43 PM
get the thumper racing big bore piston stg3 ht cam for starters just bolt on performance but youll have to get your cylinder bored professionally . they have a map you can get also
post #4 of 29 Old 08-23-2011, 09:55 PM Thread Starter
Is that hot cam gonna require me to bore it out or is it pretty much my next bolt on piece?
fhibbs12 is offline
post #5 of 29 Old 08-23-2011, 10:11 PM
No the hotcam is gona be your next bolt on step. The big bore is gona require you to have your cylinder bored to fit a larger piston. I would just go with the cam for now if it were me.
post #6 of 29 Old 08-23-2011, 10:17 PM
i got a stage 3 hot cam and the EHS big three. Made a pretty good difference up top. I would suggest getting a 11:1 cp piston at the same time.
post #7 of 29 Old 08-23-2011, 11:06 PM Thread Starter
Now would I need to get a mechanic for that or something any decent "engine guy" will be able to help me throw in on a saturday afternoon?
fhibbs12 is offline
post #8 of 29 Old 08-23-2011, 11:25 PM Thread Starter
Also, I keep reading for slightly modified bikes a stage 2 cam is better???? Sorry for the 100x questions I am just trying to make the right decision.
Most of my riding is done between 2-4 gear. Alot of trail riding so I don't want to loose much from the bottom half.
fhibbs12 is offline
post #9 of 29 Old 08-24-2011, 01:26 AM
your going to get most of your power from porting your head. the hot cam is a easy drop in that doesnt require new rockerarms or valve springs. next you can get a higher comp piston 11:1 12:1 13:1(11:1 is safe to run on pump gas 91 oct) the other require race fuel. and the +3tb will also add a lot. personally i did mine all at the same time because i did not want to be tearing down my motor everytime i got a new part just saved up and did it all at once. but it is perfectly fine to do it little by little.
post #10 of 29 Old 08-24-2011, 01:43 AM
08700xx's Avatar
you should get your head done, thats where all the power is at.
Pretty sure HDD has a +2 +1 P&P head, Web 290 cam, and springs/rockers right now, so you wouldnt have any down time.
(DL700)
Jody (Boost Addict)
08700xx is offline
