Polished Barker Exhaust? - Club700XX - Honda TRX700XX Forum
post #1 of 5 Old 08-26-2011, 07:52 PM Thread Starter
Wondering if any of you guys have polished your Barker exhaust? Mine is looking pretty rough. I would like it to be shiney like it used to be. I've tried steel wool, mother's polish, and never dull. Nothing brings back that original shine. It just looks dirty brown all the time. Suggestions???
post #2 of 5 Old 08-26-2011, 07:55 PM
boost addict's Avatar
They make them for the raptors, so it is possible. Sorry that's all i know.
The best in the business
Bo White 205-886-7043
Ed @
Chris & Mike
boost addict is offline
post #3 of 5 Old 08-26-2011, 07:56 PM Thread Starter
It say's it's 304 stainless. So it should be able to be polished?
post #4 of 5 Old 09-02-2011, 10:06 AM
From many years in the jewelry making business I know that stainless can be polished to a mirror finish, but will require some special products than can be purchased online from any of dozens of supply outlets for jewelry making.
1.
Brown Tripoli Buffing Compound... Will clean surface and provide a base for mirror polishing. Comes in a 1 pound bar @ $3.95 *Note: You will need muffler can removed to be able to turn it to get ALL surfaces. Bench mounted buffer with cloth buffing wheel works best. You will also need to clean muffler can with mild soap and water after each step to remove polishing compound residue. You don't want ANY remaining on part when you go to next step. You also need to remove it from buffing wheel. It's a wax based bar so Dawn dish soap works well.
2. Yellow Rouge Buffing Compound... For mirror finish... Also comes in 1 pound bar @ $6.50. Repeat above steps.
post #5 of 5 Old 09-02-2011, 02:36 PM
the head pipe? if so you are going to have to sand it in several stages then polish the can is aluminum i usually use a sander with a 3m finish disc gives it a good look and its really quick
EHSRACING is offline
