Engine fan question - Club700XX - Honda TRX700XX Forum
post #1 of 14 Old 08-31-2011, 11:41 PM Thread Starter
Engine fan question
I have yet to hear my electric fan turn on on my XX. Its been over 100 degrees nearly every day in august so its plenty hot for it to turn out but i havent head it. I know on my dads brute force 750 it runs, noticeably, all the time. This is the first liquid cooled quad ive owned so this is new to me. Should the fan be noticeable? and is there any way to check to see if its running?
I assume it is running because the overheating warning hasnt come on yet... unless thats broke too.
Thanks for any input
TxAggie09 is offline
post #2 of 14 Old 08-31-2011, 11:47 PM
bsurdock's Avatar
From my experience, the XX runs fairly cool. While riding in West Viriginia, my fan kicks on rarely on 90+ degree days. If i was riding slow, on the clutch alot and stuff it would come on occasionally, but not often. If im not mistaken the thermostat is set to kick it on when the temp reaches 219 degrees.
bsurdock is offline
post #3 of 14 Old 09-01-2011, 12:35 AM
Its hard to tell when the fan is running be wise its pretty quiet and you can't really feel the air hit your legs when it comes on. Probly coming on more than you realize.
post #4 of 14 Old 09-01-2011, 11:49 AM Thread Starter
Thanks for the input, ill stop worrying about it. Just dont like the idea of burning down a brand new engine, although its under warranty for the next 4 years so I should be ok.
post #5 of 14 Old 09-13-2011, 11:48 PM
After I shut down my xx, I turn the key back on. On hot days, the fan typically turns on.
Johnboywsu is offline
post #6 of 14 Old 09-14-2011, 05:50 PM
Check to see if the fan comes on whilst riding. I had a bad ECM and the only fault I found was the fan never came on. I had to pull the plug on the temp sensor near the thermostat to get it to come on.A little Mcgyver(?) moment.
post #7 of 14 Old 09-14-2011, 09:54 PM
CRAVEN7786's Avatar
Do you know if the fan was on when you turned the key off? If it was then I would guess it is normal because mine will do the same thing sometimes.
CRAVEN7786 is offline
post #8 of 14 Old 09-14-2011, 10:10 PM Thread Starter
the fan is never on when i turn the key off, even after pretty long rides when the weather is really hot, thats kinda what made me start to worry about it. The fan on my dads brute force is always running when he turns it off, even if its a shorter ride. I know thats a v-twin so its hard to compare but it is what it is.
post #9 of 14 Old 09-14-2011, 10:13 PM
CRAVEN7786's Avatar
Brute forces have the fan wired so that it can run even with the key off. The xx is not, the key has to be on.
post #10 of 14 Old 09-14-2011, 10:24 PM Thread Starter
gotcha, good to know.
