Can-link cable (dynojet) - Club700XX - Honda TRX700XX Forum
post #1 of 8 Old 09-07-2011, 06:06 PM Thread Starter
bb700xx's Avatar
I had to replace my can-link cable for my pcv to wideband2 which originally had 4 wires (white, black, red, green). The new can link from dynojet only has two wires (green, white).
? is does anyone know what the red and black wires where for, and if im using the wideband2 as an autotune, do i need the red and black wires?
Thanks for your input.
2008 HONDA 700XX.
Alba Full Exhaust
Dynojet PCV and Autotune
Lid Mod and Velocity Air Filter
HD Barnett clutch kit
13 tooth sprocket
L8ton 11/16 sway bar
Alba Pro-Elite Nerfs
Reverse rev limiter mod
23" Maxxis Razr's
22" Kenda Cutter's
CRJ front lowering kit 3.5"
22" Skat-trak 10 paddle hauler (.125 dwt)
22" GBC Dune tracker (.125 dwt)
bb700xx is offline
post #2 of 8 Old 09-07-2011, 06:19 PM
boost addict's Avatar
I would call dynojet and ask if it was me, most guys here use the dobecks.
The best in the business
Bo White 205-886-7043
Ed @
Chris & Mike
boost addict is offline
post #3 of 8 Old 09-08-2011, 02:22 PM Thread Starter
bb700xx's Avatar
Talked to dynojet today and the red and black wires were for use as digital grounds. They said on some setups the digital grounds were causeing more problems than they were worth. So they eliminated them on the new style can-link cables and do not offer the 4 wire ones anymore.
I hooked up the new can-link today, configured autotune, and it works fine displaying the AFR on the pcv software. Rode the bike for a lil bit plugged in the usb and checked the trim table and it is working, calculating the adjustments properly.
2008 HONDA 700XX.
Alba Full Exhaust
13 tooth sprocket
23" Maxxis Razr's
22" Kenda Cutter's
bb700xx is offline
post #4 of 8 Old 09-08-2011, 03:49 PM
They have awesome customer service! Glad you got it strait, i have a good pcv map for the big3 if you want to give it a try.
Ed @
Chris & Mike
post #5 of 8 Old 09-08-2011, 05:11 PM Thread Starter
bb700xx's Avatar
ya they do.
I am currently running a map from dynojet ----
M16-004-009
2009-2010 Honda TRX700XX
HMF full exhaust
Stock air filter
Air box lid removed.
It was the closest i could find to my setup. Then I figured the autotune can fine tune it fom there. It seems to run great, pulls way harder through the gears, and topend...WOW.
However, I am new to this, so I would always appreciate any suggestions.
2008 HONDA 700XX.
Alba Full Exhaust
13 tooth sprocket
23" Maxxis Razr's
22" Kenda Cutter's
bb700xx is offline
post #6 of 8 Old 09-08-2011, 06:11 PM
Pm me your email and i will send to ya. It's a great map and should get you very close, then let the autotune do it's job
Ed @
Chris & Mike
post #7 of 8 Old 09-08-2011, 07:49 PM
Originally Posted by bb700xx View Post
ya they do.
M16-004-009
HMF full exhaust
Stock air filter
Just wondering with all the upgrades you listed, why in the world are you still using the stock filter? OIC those are the setting for your map, nevermind....sry
post #8 of 8 Old 09-09-2011, 09:38 AM Thread Starter
bb700xx's Avatar
pm sent.. thank you.
2008 HONDA 700XX.
Alba Full Exhaust
13 tooth sprocket
23" Maxxis Razr's
22" Kenda Cutter's
bb700xx is offline
