Top End Gasket - Club700XX - Honda TRX700XX Forum
post #1 of 4 Old 09-08-2011, 04:59 PM Thread Starter
Top End Gasket
I bought a top end gasket kit the other day to go with my soon to be motor build and while I was looking at the package I noticed it said 104mm on the package. I know the bore size for the cylinder is 102mm. Any ideas as to what the 104 is for?
post #2 of 4 Old 09-09-2011, 07:09 AM
overbore size, it will probably be ok and on a lot of bikes it doesnt make a hole heck of a lot of difference with a slightly larger bore for head gasket. but the xx has a pretty narrow sealing area to begin with having the correct size is a good idea but that would probably work
EHSRACING is offline
post #3 of 4 Old 09-09-2011, 08:30 AM Thread Starter
I think ill just get the factory oem gaskets I want them to be right.
post #4 of 4 Old 09-09-2011, 08:37 AM
boost addict's Avatar
When i had my bb, i had custom MLS 106mm gaskets made for the 105mm bore. +2mm over the stock bore is pushing it imo. Get the oem gaskets!!
The best in the business
Bo White 205-886-7043
Ed @
Chris & Mike
boost addict is offline
