Transmission Problems - Club700XX - Honda TRX700XX Forum
post #1 of 4 Old 09-11-2011, 05:28 AM Thread Starter
I have had gear change problems. It would be fine in 1st,2nd and 3rd but 4th was a real pain and jumped into 5th instead.
Changing down was a bigger problem. To try and change from 5th to 4th , I had to change down 3 or 4 times on the lever and had no 3rd or 4th .
I took the motor out on Friday and stripped it down this morning and found the problem. The gear changer linkage has a small piece missing on the end of one the pawls.
Must of had something hit the gear lever when last doing a XC.
Quite glad it is only a $60 part and not a transmission rebuild.
post #2 of 4 Old 09-11-2011, 11:20 AM
Wow! Good find and am glad that it was not an internal part $$$
post #3 of 4 Old 08-06-2017, 04:26 AM
Hey there where abouts is the location of this my dads trx700xx has done the same thing and I can't find a picture of the part or location anywhere
Thanks in advance
Liam Jones is offline
post #4 of 4 Old 08-06-2017, 11:27 AM
Quoted: 252 Post(s)
Thanks in advance
I believe it's part #9 in this diagram. It's the piece the foot shifter connects too.
Honda ATV Parts 2009 TRX700XX A GEAR SHIFT DRUM + GEAR SHIFT FORK Diagram
