Rev Limit? - Club700XX - Honda TRX700XX Forum
post #1 of 9 Old 09-13-2011, 02:55 PM Thread Starter
Rev Limit?
Does anyone know the rev limit on these 700xx engines? I am in need of this information for a college project.
Thanks for the help
2008 Black/Grey TRX700XX:
EHS Airbox & Uni Filter
13t Front Sprocket
Motoworks Exhaust System
PRM Bumper
Quad Boss Rack
Ds450 Shocks
L8ton Sway Bar
Stabilizer
MotionPro Twist Throttle
Pro Armor Nerfs
Winch Installed
Reverse Rev Limit Uninstalled
"Trust in the LORD with all your heart and lean not on your own understanding; in all thy ways acknowledge Him and He shall direct thy paths." Proverbs 3:5-6
Black&Blue7XX is offline
post #2 of 9 Old 09-13-2011, 05:39 PM
TRX700XXX's Avatar
8750 if I remember correctly.
TRX700XXX is offline
post #3 of 9 Old 09-13-2011, 10:50 PM Thread Starter
Thanks! Is that in the owners manual?......I'm not home around my xx to check
13t Front Sprocket
PRM Bumper
Quad Boss Rack
Ds450 Shocks
L8ton Sway Bar
Stabilizer
Pro Armor Nerfs
Winch Installed
post #4 of 9 Old 09-13-2011, 11:41 PM
TRX700XXX's Avatar
I just checked the manual but couldn't find it but I'm pretty sure 8750 is correct.
post #5 of 9 Old 09-14-2011, 01:49 PM
DL700's Avatar
DL700 is offline
post #6 of 9 Old 09-14-2011, 09:51 PM
you were dam close !
post #7 of 9 Old 09-14-2011, 10:28 PM
TRX700XXX's Avatar
On the Two Brothers dyno it shows 8750 in the top right for max rpm.
http://www.twobros.com/Cust_Service/Dyno_Charts/dyno_2008_hon_trx700_SO.pdf
post #8 of 9 Old 09-15-2011, 01:10 AM
DL700's Avatar
naw 8600 if your lucky... ive got about 10 pulls up to the limiter on file, Rap 700 pulls 8800 rpm and there is a difference for sure
DL700 is offline
post #9 of 9 Old 09-15-2011, 01:16 AM
DL700's Avatar
thats 5th gear.... 2 different bike
DL700 is offline
