uni filter oil - Club700XX - Honda TRX700XX Forum
post #1 of 12 Old 09-16-2011, 07:38 PM Thread Starter
uni filter oil
i got my uni filter today from ups but I don't have any of the uni filter oil, is there some other filter oil I can use until I can get a can of the uni filter oil?
iceman320 is offline
post #2 of 12 Old 09-16-2011, 07:50 PM
You can use any type of foam filter oil.
post #3 of 12 Old 09-16-2011, 09:53 PM Thread Starter
could I use the foam filter oil that's for foam chain saw filters?
post #4 of 12 Old 09-16-2011, 11:53 PM
Idk about that, but Im not a lumber jack. I use the PJ1 spray on type, much easier to apply.
post #5 of 12 Old 09-17-2011, 02:21 PM
Here is my favorite. http://www.belray.com/bel-ray-foam-filter-oil
If you are in a bind, motor oil will work. That is all I used to run, but the purpose made filter oils do a better job of catching stuff and staying on the filter.
post #6 of 12 Old 09-17-2011, 05:51 PM
iceman320,
I'm a PJ1 Filter Treatment person too. I use the cleaner (PJ1 Cleaner Spray) to dissolve the PJ1 Filter Treatment when it is time to clean the filter and wash with water. The Filter Treatment (PJ1) (red in color) will just flow out with the water. Let dry and recoat with the treatment spray.
post #7 of 12 Old 09-17-2011, 06:03 PM
I like silkolene foam filter oil. Its really tacky and does a good job catching the dirt.
post #8 of 12 Old 09-17-2011, 09:24 PM
I always use the uni oil. It sticks to the filter really good and doesn't run off into the bottom of the airbox.
post #9 of 12 Old 09-18-2011, 10:36 AM
i use the uni spray on oil and spray cleaner, it works like the pj1 combo.
post #10 of 12 Old 09-18-2011, 11:32 AM
Bel Ray FTMFW!!!!
2006 Raptor 700
