Change spark plug - Club700XX - Honda TRX700XX Forum
post #1 of 12 Old 09-18-2011, 04:08 PM Thread Starter
Change spark plug
I have a 2008 I am trying to change the spark plug what is the easiest way to do this I can't seem to get the spark plug tool on the plug to get it out. Looking for ideas thanks
bblack0413 is offline
post #2 of 12 Old 09-18-2011, 04:17 PM
Did you pull the tank? I typically take the opportunity to check the valve clearance at the same time.
Johnboywsu is offline
post #3 of 12 Old 09-18-2011, 07:13 PM Thread Starter
No is that what i need to do pull the Tank to put a new plug in
post #4 of 12 Old 09-18-2011, 07:20 PM
240
You don't have to pull off the tank but you might have a few choice words with out removing it. I can get mine off without removing tank but its not fun.
240 is offline
post #5 of 12 Old 09-18-2011, 08:25 PM
puke
its a buger i use latex gloves to thread it in an thread it out i can grip the sparkplug better that way thats without taking tank off
post #6 of 12 Old 09-18-2011, 09:02 PM
This thread is confusing me....
Isn't it your typical deep well socket and short handled ratchet. I tighten it with my fingers till snug. Slide the socket in and give in another 1/2ish turn. Pop the cap on and done.
I change plugs constantly.
fhibbs12 is offline
post #7 of 12 Old 09-18-2011, 09:20 PM
Stevem12065's Avatar
Its the position of the plug it is hard to get to.
2008 Black on Black 700XX
Pro Armor Fat Peg Nerfs and Bullhorn Bumper Black
Uni Filter w/EHS/Barkers BIG 3
13 Tooth front
9/16 L8ton sway and Alba stabilizer
2007 Rancher 420 Red
2wd Electric Shift
Uni Filter w/Hmf Slip on and Optimizer
Tusk Flex Handgaurds
Stevem12065 is offline
post #8 of 12 Old 09-18-2011, 09:23 PM
Guess I am just used to it then from all the plug chops i've had to do :-/ Hardest thing in my opinion is just getting the yellow cap off.
fhibbs12 is offline
post #9 of 12 Old 09-19-2011, 12:06 PM
Right on the plug wire/cap sometimes sticks pretty good. And I just used the plug tool that came with the quad.
post #10 of 12 Old 09-19-2011, 06:44 PM
I learnt the hard way and this way I found alot easier. I have big hands and can't reach the plug. I put the plug in the socket first then fit it hand tight, then tighten with a knuckle bar. It's easy when you get the knack of it.Put some lube on the cap, makes easy to get on and off.
