Sparks X-6 Exhaust Question - Club700XX - Honda TRX700XX Forum
post #1 of 16 Old 09-18-2011, 09:33 PM Thread Starter
92K1500's Avatar
I did a search, so don't tell me to search.
Does anyone other than Boost Addict have the Sparks exhaust? I was curious if anyone knows if it will clear the PRM Desert grab bar. I'm thinkin about picking up the X-6 and it was just something that crossed my mind.
2008 Honda TRX700XX
AC Racing MX Nerf Bars.
PRM Desert Grab Bar.
92K1500 is offline
post #2 of 16 Old 09-18-2011, 09:45 PM
I have it, although I don't know if it will clear the PRM grab bar. It does come up flush with the stock grab bar though.
post #3 of 16 Old 09-18-2011, 10:47 PM Thread Starter
92K1500's Avatar
How do you like it?
If it's worth buying I might have to get creative with my grab bar.
2008 Honda TRX700XX
92K1500 is offline
post #4 of 16 Old 09-18-2011, 10:48 PM Thread Starter
92K1500's Avatar
Also could you get some pics/measurements? Like from the mount bolt to the tip etc...
That way I can compare it to my stock one to see if it will work or not.
2008 Honda TRX700XX
92K1500 is offline
post #5 of 16 Old 09-18-2011, 11:16 PM
08700xx's Avatar
I have the Sparks X6 big core and love it.
(DL700)
Jody (Boost Addict)
08700xx is offline
post #6 of 16 Old 09-18-2011, 11:21 PM Thread Starter
92K1500's Avatar
Where is the best place to buy?
I can only find it on their site and I only see the one option.
I don't want really loud, I just wanna open up the power within so I can put the 14t back on the front and still do fine in the tight trails. I hate how much the 13t kills the top speed. I'm topped out and my buddies are still in 4th.
2008 Honda TRX700XX
92K1500 is offline
post #7 of 16 Old 09-18-2011, 11:24 PM
JBGILL06's Avatar
I love my Sparks. I didn't think any aftermarket exhausts could be as loud and beautiful sounding like my Rincons Swamp Series XL. I was wrong.
2008 Honda TRX700XX
*Power Commander V
*Pro Design Air Filter
*Elka Stage One Shocks
*Pro Taper Evo Bars
*Trail Tech Big Bar Clamp
*MSR Clutch Perch
*Powermadd Handguards
*ODI Rogue Grips
*IMS 5gal Tank
*Pro Armor XC Bumper
*PRM Full Skid Plates
*Maxxis Razr II Tires
*ITP Aluminum Rims
2007 Honda Rincon GPScape
JBGILL06 is offline
post #8 of 16 Old 09-18-2011, 11:30 PM
08700xx's Avatar
I just called sparks and ordered mine over the phone. The big core that Jody and I have is louder than the regular X6 and you can't run the quite core (I think sparks calls it a quite tip or something like that) on the big core either so you probably want to stick with the X6. The sparks is the best made exhaust for the XX that I've seen, I'm very happy with its sound, appearance and performance too.
(DL700)
Jody (Boost Addict)
08700xx is offline
post #9 of 16 Old 09-19-2011, 12:13 AM
i dont belive it will from pics ive seen you will have to notch out part of your grab bar. not 100% sure but i think my dmc exhaust is the only one that clears it and by that i mean i can silde a penny between the two.
post #10 of 16 Old 09-19-2011, 12:44 AM Thread Starter
92K1500's Avatar
I just don't wanna have to completely cut out the support. Then it'd be pointless to have the wide bar. If a penny is all the clearance I have I'll be happy.
I don't mind grinding a little off the bottom side.
I guess there is only one way to find out. I'll probably be buying it and a PC5 either mid winter or in the spring. Got other projects I gotta finish first.
2008 Honda TRX700XX
92K1500 is offline
