FMF programmer w/HMF competition exhaust - Club700XX - Honda TRX700XX Forum
post #1 of 10 Old 09-28-2011, 06:33 PM Thread Starter
Just installed a FMF programmer, have an hmf competition exhaust, went down a tooth on front sprocket, and have a uni air filter installed. I know NOTHING about programmers, is there any setting that is "best" or what's the best way to create your own setting? I live in Ohio and mainly ride wooded trails or hills in hillsville, don't race or anything like that.
thanks, you guys are much better than google lol
downazziggy is offline
post #2 of 10 Old 09-28-2011, 06:56 PM
Didn't FMF give u the map when you bought the stuff?
post #3 of 10 Old 09-28-2011, 10:42 PM
traitor08's Avatar
Should of included setting for different setups. Can you send it back and buy an ehs? Just asking.
MY RIDES
Amish washing the buggy^^^^
traitor08 is offline
post #4 of 10 Old 09-29-2011, 12:19 AM
Rastled's Avatar
To program FMF settings
Ok guys here is the official "easy way to understand the tuneability of the FMF tuner. (way easier than the instructions, IMO)
----> Mode button = navigate modes
----> +/- buttons = settings .5-8 in .5 increments (.5,1,1.5,2,2.5,3 etc through 8) represented as a increase (higher number), decrease (lower number).
----> 6 different Modes represented by LED color as follows
MODES:
1 = Green = amount of ]fuel[added under cruise condition. (.5 = stock/invisible)
2 = Yellow = amount of fuel added during acceleration. (.5 = stock/invisible)
3 = Red = amount of fuel added during full]throttle[ or WOT (.5 = stock/ ")
4 = Green/Blue = Point at which the RPM Range When in Cruise Mode is turned on. (.5 = 1,000rpm) (8 = 2,800rpm)
MODES:
1 = Green = amount of ]fuel[ added under cruise condition. (.5 = stock/invisible)
3 = Red = amount of fuel added during full ]throttle[ or WOT (.5 = stock/ ")
5 = Yellow/Blue = Adjustment of delay in acceleration mode fuel turns on. (.5 = sooner, 8 = later)
6 = Red/Blue = Adjustment of delay in full throttle or WOT mode fuel turns on.
ie: taken from an older post for setting up your settings.
old post was here: http://www.thumpertalk.com/forum/arc.../t-664899.html
posted by
Steveakus
07-03-2008, 05:27 PM
His finalized tweaked settings (maybe something to start with) below:
My current settings after about 6 runs and experimenting is
Mode 1 = 1.5
Mode 2 = 5
Mode 3 = 6
Mode 4 = 2
Mode 5 = 2
Mode 6 = 3
scuzz and smooth1 posted
http://www.exriders.com/archive/topic/373506-1.html
Maybe with their past experience could help you a bit more for the best tweaks to start with and need.
Rastled is offline
post #5 of 10 Old 09-29-2011, 02:21 PM Thread Starter
can't take it back and get an EHS, i contacted erik 2x trying to get them to put one on ebay because i had a credit of 260 because i got screwed when purchasing the exhaust the guy never sent it so i had to use that money w/ebay but erik nor anyone at EHS ever contacted me back about being able to do that so got stuck w/the fmf. it comes with their dif. modes and all that stuff but i have no clue what it means its all just a bunch of dif colors and what not lol..just gonna take it to the guy at the shop i go to he's pretty good w/all that stuff and let him tweak it to whatever he thinks is best for the quad...thanks
post #6 of 10 Old 09-29-2011, 02:24 PM
I can give you a map that should work ok
post #7 of 10 Old 09-29-2011, 02:33 PM Thread Starter
i'm a moron they do have the recommended settings its
mode 1 = 2
mode 2 = 2
mode 3 = 3 (said might be boggy and drop it down to 2 if so)
mode 4 = 4
mode 5 = 4
mode 6 = 4
way off from above posted will try these out and if they don't work will try the ones listed above
post #8 of 10 Old 09-29-2011, 03:02 PM Thread Starter
just took it for a quick spin, did bog out when high in 3rd and 4th so dropped mode 3 down to 2 and that fixed that.. shoot me that map when you have time red n black..
post #9 of 10 Old 09-29-2011, 03:06 PM
are you running a lid?
post #10 of 10 Old 09-29-2011, 03:11 PM
Also it is a full exhaust right?
