Ali rear sprocket - Club700XX - Honda TRX700XX Forum
post #1 of 16 Old 10-06-2011, 05:11 PM Thread Starter
Ali rear sprocket
I would like to know if anybody has used a Moose Racing or PBI Ali rear sprocket and how did it do ?
Also would you go for Ali one again or buy a steel one ?
Thanks.
post #2 of 16 Old 10-06-2011, 07:58 PM
DL700's Avatar
pbi has Much better life then the Renthal aluminum ones but for us they dont handle the power and only last about a weekend
DL700 is offline
post #3 of 16 Old 10-08-2011, 06:06 PM Thread Starter
If they last a weekend with the kinda power you are running then they should work fine for me.
Cheers Dan.
post #4 of 16 Old 10-11-2011, 04:57 AM
DL700's Avatar
bad thing about aluminum vs steeel is the teeth will chip off or break off entirely, vs a steel tooth curving over...wont hurt to try one and see how it last
DL700 is offline
post #5 of 16 Old 10-13-2011, 06:43 PM Thread Starter
A PBI 39t ali sprocket cost about £40 including shipping, getting a steel 39t sprocket made will be about £150+. So if a use a couple during the year it would still work out cheaper. Changing the rear sprocket only takes 5 mins including beer.
post #6 of 16 Old 10-13-2011, 08:03 PM
grin
in that case i will need some lessons from you soon my sprockets and chain is about wore out, they lasted2 years the stockers not bad i dont know how many miles is on them but its about 300hrs on my hour meter
post #7 of 16 Old 10-13-2011, 08:25 PM Thread Starter
I will do a how to when I change mine with lots of pics etc.
post #8 of 16 Old 10-13-2011, 08:41 PM
grin
very appreciated
post #9 of 16 Old 10-14-2011, 12:49 AM
DL700's Avatar
Thats a great reason to give em a try!!
DL700 is offline
post #10 of 16 Old 10-14-2011, 05:56 PM
chain and sprockets should be changed together as just changing the chain or sprocket will lead to premature wear.
I once used an ally rear sprocket and it wore pretty fast..
so then do you replace it with a steel one which will then have a partly worn chain on it, or replace the whole lot again?
Personally i would never use an aluminium sprocket again.
rappey is offline
