Going in? - Club700XX - Honda TRX700XX Forum
post #1 of 8 Old 10-10-2011, 02:22 PM Thread Starter
240
Going in?
Is there much to going into the engine as far as the bottom of the cylinder(removing cylinder)? I haven't done it before but I catch on to things quick. Any advice or special tools I should know about?
240 is offline
post #2 of 8 Old 10-10-2011, 04:04 PM
Taking the cylinder off is pretty easy just follow the service manual instructions. You don't not need the cam chain tensioner tool. Just remove the tensioner all together for disassembly.
post #3 of 8 Old 10-10-2011, 04:38 PM
boost addict's Avatar
Also new oem(1) base and(1) head gaskets. 45 ft lbs on the head bolts any more and you will stretch them. The only other thing you need to worry about is the ring gap, but that will depend on which piston you use.
The best in the business
Bo White 205-886-7043
Ed @
Chris & Mike
boost addict is offline
post #4 of 8 Old 10-10-2011, 05:30 PM
And take your time to label all the different bolts and small parts. Its really a simple motor to work on.
post #5 of 8 Old 10-10-2011, 06:24 PM
And stay away from the booze while doing!!!
post #6 of 8 Old 10-10-2011, 06:33 PM
mquez700xx's Avatar
MODS ---
L8ton 9/16 sway bar
L8ton bumper
Tusck Hand Guards
EHS Big 3
Elka Stage 3 shocks
K&N Filter with outearwear
UNI Air Filter For dusty terains
Vapor computer
X Bar with vapor clamp
Spider Grip
TRX shock covers
Smoke headlight cover
Alba Racing Nerfs
Razs Tires
mquez700xx is offline
post #7 of 8 Old 10-10-2011, 06:43 PM
Party pooper
Ed @
Chris & Mike
post #8 of 8 Old 10-10-2011, 07:52 PM
The service manual, if you don't already have it.
https://www.club700xx.com/vb/showthread.php?t=2195
Ed @
Chris & Mike
