Exhaust ?? - Club700XX - Honda TRX700XX Forum
post #1 of 18 Old 10-13-2011, 01:20 PM Thread Starter
Exhaust ??
I want more power on my 700xx but here aftermarket exhaust are illegal, wondering if I can just replace the stock header and air filter ?
If not then is there anything stealthy and that wouldn't be too loud that could give me a bit of hp more. Thanks.
NavyNut is offline
post #2 of 18 Old 10-13-2011, 06:41 PM
IDK about replacing the header and using factory pipe? But have herd just adding a programer and a filter will help a little.
post #3 of 18 Old 10-13-2011, 06:48 PM
2 of the quietest, I have found is FMF and Leo Vince. The FMF is alot cheaper.
Thats all I am running and it does help out .
post #4 of 18 Old 10-13-2011, 07:39 PM
why are they illegal there? if you cant get exhaust youll have to do an cam an piston then if you want to spend more money get a port and polish job too
post #5 of 18 Old 10-14-2011, 02:39 PM
But would you want to build the engine, if you cant let the power out the exhaust?
post #6 of 18 Old 10-14-2011, 08:08 PM Thread Starter
Can I remove the decal of the barker exhaust ? Any other brand where it would be easy to remove decals and it would mostly look stock ?
NavyNut is offline
post #7 of 18 Old 10-14-2011, 09:15 PM
its not an decal its aluminum and it is rivited to the cannister you can request barker not to put it there , all its going to do is fade and loose its color over time anyway from the heat the next one i buy is going to be minus that emblem because of that mine was red now its almost pink after 2 years of wear and tear and the anodized red muffler clamp is fading too
post #8 of 18 Old 10-14-2011, 09:24 PM Thread Starter
Ok, I'll check it out. How does the ehs stuff holds with time ? Does it requires frequent repack ?
NavyNut is offline
post #9 of 18 Old 10-15-2011, 08:14 AM
Motoworks would be a nice exhaust you can peel the metal decal off and it pretty mellow if you leave the spark arrestor in it.
post #10 of 18 Old 10-15-2011, 10:21 AM
twice a year with me
