Valve Train Noise Revisited - Club700XX - Honda TRX700XX Forum
post #1 of 37 Old 10-15-2011, 10:12 PM Thread Starter
1dmbhonkey's Avatar
I reset the valve lash AGAIN on my hotcam stage 2...... This time I set them tight @ .013 and .018mm and the noise is better but still seems quite loud to me (when its hot). I guess I should just let this issue go but I would feel better if I knew that other people hear this same noise on their hotcam equipt bikes.
1dmbhonkey is offline
post #2 of 37 Old 10-15-2011, 11:22 PM
I thought the valve lash was supposed to be. 006 on the intake and .008 on the exhaust?
post #3 of 37 Old 10-15-2011, 11:38 PM Thread Starter
1dmbhonkey's Avatar
That's inches ^
post #4 of 37 Old 10-16-2011, 01:42 AM
DL700's Avatar
after setting your lash rotate the motor over slowly(by hand) use the next size up on the feeler gauge set and check the lash in several different spots of the lobe base,,, if u find a spot where the gauge goes in then readjust at that location
DL700 is offline
post #5 of 37 Old 10-16-2011, 10:15 AM Thread Starter
1dmbhonkey's Avatar
Here is a clip of a hot start with the tighter lash settings...... If you listen close you can hear the noise
rtsp://v4.cache7.c.youtube.com/CjYLENy73wIaLQmSxXqQ5AO8WBMYJCAkFEIJbXYtZ29vZ2xlSA RSBXdhdGNoYMnm4PyCkaHLTgw=/0/0/0/video.3gp
post #6 of 37 Old 10-16-2011, 10:28 AM Thread Starter
1dmbhonkey's Avatar
Try this I did the other one from my phone
http://youtu.be/WLwD5JB6xZI
post #7 of 37 Old 10-16-2011, 10:50 AM
headscratch
i can hear it ticking pretty good in the vid, its a little louder than stock. shouldnt the valve train noise sound like stock because you still got the stock springs and rockers? wish you could find the prob because im thinkin of gettin stg3 hot cam this winter and 11:1 piston
post #8 of 37 Old 10-16-2011, 11:15 AM Thread Starter
1dmbhonkey's Avatar
Its not loud at all until it gets hot
post #9 of 37 Old 10-16-2011, 11:31 AM
wonder if it could be the cam chain slapping in there. the tensioner and cam chain may be wore , my 400ex was bad about them wearin out the 400ex guys are strarting to use 450r cam chains to upgrade
post #10 of 37 Old 10-16-2011, 11:36 AM
Originally Posted by 1dmbhonkey View Post
That's inches ^
Sry didn't see the "mm"
