HC3 Install trouble - Club700XX - Honda TRX700XX Forum
post #1 of 26 Old 10-27-2011, 06:45 AM Thread Starter
HC3 Install trouble
Hey all i am installing a cam in for a guy here local, this is first honda 700 i have seen and i must say it ran very well. Anyways i got cam installed followed by service manual. Lobes down at TDC compression stroke and timing marks spot on. Rotates fine everything was going smooth. Bolted head cover on and rotates to a certain point and stops due to hitting something. Ive tried looking and going both ways and i cant see quite what it is. Took cover off and double checked my work and all looked good, installed again and we have same problem. Almost seems like rocker arm needs clearanced. Ive went step by step per manual and now im stuck and need some help. Any help is appreciated
Juggernaut_7 is offline
post #2 of 26 Old 10-27-2011, 07:02 AM
boost addict's Avatar
Sounds like you did everything correct. I have never used a HC, but have installed 3 different Webb cams in the XX with no issues. Here is the manual if you want to double check it.
https://www.club700xx.com/vb/showthread.php?t=2195
The best in the business
Bo White 205-886-7043
Ed @
Chris & Mike
boost addict is offline
post #3 of 26 Old 10-27-2011, 07:49 AM
1dmbhonkey's Avatar
Are the timing marks aligned with the deck correctly?? I know that sounds like a dumb question but its easy to do. Maybe the valves are hitting the piston. HC3's are supposed to be drop ins.
1dmbhonkey is offline
post #4 of 26 Old 10-27-2011, 08:16 AM
you dont need any clearenceing for a hot cam you must have something installed a little wrong. the big cams dont need any clearence either. did you put the decomp in correctly or at all?
EHSRACING is offline
post #5 of 26 Old 10-27-2011, 09:11 AM
1dmbhonkey's Avatar
post #6 of 26 Old 10-27-2011, 09:23 AM
1dmbhonkey's Avatar
Thats RIGHT ^^^
post #7 of 26 Old 10-27-2011, 09:25 AM
1dmbhonkey's Avatar
Thats WRONG^^^
post #8 of 26 Old 10-27-2011, 05:12 PM Thread Starter
Yea I installed it as paper said with hot cam looks right. Something is hitting around rocker arms cuz without head cover rotates great. Timing marks look spot on also.
post #9 of 26 Old 10-28-2011, 08:50 PM Thread Starter
Heres the pics i snapped check it out...
post #10 of 26 Old 10-28-2011, 08:52 PM Thread Starter
Mine looks like one above thats supposed to be right, not sure where my problem is at. Even looked at decomp and according to hot cam sheet it looks right to me.
