Where can I find a fitting on the motor where I can check oil pressure. - Club700XX - Honda TRX700XX Forum
post #1 of 6 Old 10-31-2011, 11:11 AM Thread Starter
I'm looking for a spot where I can, borrow some oil for a very nice little toy I'm adding on. Anyone knows where I can steal oil at on the motor?
NOLATRX700XX is offline
post #2 of 6 Old 10-31-2011, 05:36 PM
traitor08's Avatar
Turbo???
MY RIDES
Amish washing the buggy^^^^
traitor08 is offline
post #3 of 6 Old 11-01-2011, 06:22 AM Thread Starter
Yea just need a place to tap in for the oil. I'm not trying to cut the line to the reservoir but, it looks like that's what I'll have to do. I only
Need at most 8psi of oil running to it.
post #4 of 6 Old 11-01-2011, 04:14 PM
CRAVEN7786's Avatar
The "oil check bolt" as the manual calls it may work
Page 4-12 in the service manual(page 76 in the PDF version)
If you don't already have the service manual...
https://www.club700xx.com/vb/showthread.php?t=2195
CRAVEN7786 is offline
post #5 of 6 Old 11-02-2011, 04:10 PM
There is some plugs around the oil filter housing. You would need the manual to see ,which plug did what. Theres 4 of them feed and return from both oil pumps. Personally I would build a seperate oil system for the turbo.
post #6 of 6 Old 11-17-2011, 04:28 PM
I looked into this more due to a project , I am working on and I would tap into the second pump.This basically controls the amount of oil in the motor and has a filter screen inside the motor. This pump is mainly used for cooling but has no pressure relief valve and is about 3 times the volume capacity of the first pump that lubes the motor (Crank,tranny and other things). If youre gunna fit a turbo ,I would put a oil cooler in also.
