Oil in coolant - Club700XX - Honda TRX700XX Forum
post #1 of 5 Old 11-01-2011, 03:28 PM Thread Starter
Oil in coolant
We use the entire running gear from a TRX700XX in our asphalt race buggy call Motobuggy. (There's some stuff about it on facebook)
At our last test, it appears that oil got in the coolant and it was whipped into a coffee colored foam that plugged up the water pump and radiator before all circulation stopped.
Compression is above specs and there are no outward signs of a blown head gasket. Oil pressure is good. There's also no sign that oil leaked past the oil pump shaft seal.
Any ideas on how the oil got in the water other than a blown head gasket or water pump seal would be much appreciated.
motobuggy is offline
post #2 of 5 Old 11-01-2011, 03:54 PM
scrawny's Avatar
a bad head that is cracked could leak right through the casting.
08 700xx
05 Ruckus
04 450r
86 Fat Cat
86 350x
81 250r
72 CB100
scrawny is offline
post #3 of 5 Old 11-05-2011, 10:51 PM Thread Starter
Thanks for the reply. It looks like we figured it out: we mixed incompatible coolants, amber with green. I wouldn't have thought it possible that they would gum up like that, but we saved an unnecessary engine teardown.
post #4 of 5 Old 11-07-2011, 08:48 PM
AusTrx700xx's Avatar
Do you have coolant in the oli? As in coolant in the sump, caus if it's a blown head you will normally find coolant in te oli and oil in the coolant,
All readyto roost thanks to
Mike at Quadparts.com.au
Team IMS imsproducts.com
George at MonsterLab Atv
Kimberly Motorcycles
Minshull Mechanical Repairs
AusTrx700xx is offline
post #5 of 5 Old 11-07-2011, 08:49 PM
Should really read all posts before I say anything, glad you got it sorted
