700XX pistons - Club700XX - Honda TRX700XX Forum
post #1 of 13 Old 11-06-2011, 04:58 PM Thread Starter
700XX pistons
where is the best place to buy CP pistons for the 700 ?
post #2 of 13 Old 11-06-2011, 08:05 PM
boost addict's Avatar
Daniel @ HDD or Nate @ Alba has them in stock. You also need a base and head gasket
The best in the business
Bo White 205-886-7043
Ed @
Chris & Mike
boost addict is offline
post #3 of 13 Old 11-06-2011, 08:25 PM
I usually have them also
EHSRACING is offline
post #4 of 13 Old 11-11-2011, 10:07 AM Thread Starter
headscratch
you guys that are running the cp 11:1 are you getting the anti friction coating on them or does it matter. the stock piston comes with a coating i think?
post #5 of 13 Old 11-11-2011, 04:41 PM
I didnt even know that was an option. Im pretty sure mine doesnot have the coating.
post #6 of 13 Old 11-11-2011, 06:04 PM
These are your standard "off the shelf" pistons cp sells for the 700xx.
http://www.campbellenterprises.com/h...cp-pistons.php
The are not anti-friction coated/ Nikasil pistons. The oem Aluminum cyclinder has a steel sleeve, so no need for the pistons to be Nikasil coated IMO. You can have them custom ordered through CP, if you order 3 pistons.
Ed @
Chris & Mike
post #7 of 13 Old 11-11-2011, 06:25 PM Thread Starter
thanks for the info in never heard of a piston being nikasil coated , i have heard of ceramic coated piston on the thumper racing ktm 600cc in dirt wheels this month and some kind of teflon coating for friction from cp. i think cylinder works kits have a nikasil sleeve or coating on there cylinders, if the cylinder is nikasil can they be bored out?
post #8 of 13 Old 11-11-2011, 06:30 PM
Sorry maybe i should have said the pistons don't come anti-friction coated unless you special order them. If you bore out a nikasil sleeve cylinder you MUST get it nikasil coated again.
Ed @
Chris & Mike
post #9 of 13 Old 11-11-2011, 06:32 PM
You don't have to worry about any of this with the XX Also use the OEM head and base gaskets for the stock bore Pistons , not the MLS gaskets.
Ed @
Chris & Mike
post #10 of 13 Old 11-11-2011, 07:15 PM Thread Starter
grin
i appreciate the info boost, im planning on doing this , this winter. thanks
