Slight bog - Club700XX - Honda TRX700XX Forum
post #1 of 10 Old 11-07-2011, 07:59 AM Thread Starter
Slight bog
I've had my xx for about 3months now and I have a slight bog in the engine has anyone else had this issue?
proudXXowner is offline
post #2 of 10 Old 11-07-2011, 09:17 AM
how dirty and old is the air filter?
post #3 of 10 Old 11-07-2011, 12:12 PM Thread Starter
like brand new and its still stock one i havent rode it enough to get it dirty
post #4 of 10 Old 11-07-2011, 12:19 PM
Do you have a fuel controller or is the bike stock?
post #5 of 10 Old 11-07-2011, 12:29 PM Thread Starter
its all stock
post #6 of 10 Old 11-07-2011, 05:53 PM
What kind of bog? While your riding it or just revving it while in neutral? We need more info.
post #7 of 10 Old 11-07-2011, 08:16 PM Thread Starter
while in neutral and when i go from reverse to 1st itll have no power and if you give it gas even taking off easy itll die
stock for now.
post #8 of 10 Old 11-07-2011, 08:53 PM
laughing
in reverse it is regulated to very low rpms it will cut out past 1/8 throttle.
post #9 of 10 Old 11-07-2011, 09:28 PM
proudXXowner,
Be sure to let the machine warm up a little and only use fresh 93 Octane fuel in it.
Note-1 After the XX is warmed up a little it will tend to lurch forward slightly when going from Neutral to First Gear.
Note-2 Iím not sure where you are located but donít be afraid of using the required amount of Sta-Bil Gasoline Treatment in your fuel to keep it fresh during the winter months.
post #10 of 10 Old 11-08-2011, 10:06 PM Thread Starter
im in mideatern indiana thanks a bunch for the help guys
stock for now.
