Thoughts on fuel Octane - Club700XX - Honda TRX700XX Forum
post #1 of 23 Old 11-08-2011, 10:19 AM Thread Starter
1dmbhonkey's Avatar
I've recently read some post about fuel octane. Many stating that 93 octane is the min. for this motor. I personally have run 89 octane since the the day I brought it home (with no prolbems..ping exct. even with big three +cam), mostly because thats the highest I can get in my home town (Southern Illinois @ sea level). I do have access to 93 but its a 20 min drive. Anyway my thought is this.... would'nt you be better off running the LOWEST octane your engine could safely burn since the HIGHER octane fuel is actually harder to ingnite?? It seems to me that the only way to extract more power from higher octane fuel is to either add compression (I guess a cam could raise compression psi) or alter timing. Feel free to straighten me out...... comments are welcome.
1dmbhonkey is offline
post #2 of 23 Old 11-08-2011, 11:11 AM
If you can run a lower octane without ping and stuff... Then, it should be OK.
The higher the compression, the higher the octane needed. Higher octane fuels aren't harder to ignite, but they are more stable under higher compression... think of how diesel fuel fires. Lower octane fuels can pre-ignite (ping) under high compression... but higher octane can handle the high compression and not ignite FROM the compression like diesel fuel and lower octane fuels. But, when you add in the ethanol they mix with gas in the mid-west... ??
post #3 of 23 Old 11-08-2011, 11:53 AM
Living in California, I'm not sure what is done to the gasoline. I've used the lower octane with undesirable results. The 93 appears to work better in this machine. The manual says to use the higher rated fuel so I do it. I am at 2300 feet here and in the summer I noticed some pinging with the lower rated gasoline. Truly, with California changing from summer to winter blends (more or less oxygenators); it is hard to say how any vehicle can survive without reacting.
post #4 of 23 Old 11-08-2011, 12:13 PM Thread Starter
1dmbhonkey's Avatar
I built a small block chevy several years back with 11.25 to 1 compression and cast iron heads..... had to run it on 93
post #5 of 23 Old 11-08-2011, 12:20 PM
93 is readily available around me so that's what I use. Manual says premium fuel only and gas loses octain as it sits. So if my bike sits a couple months without riding. I put fresh gas in it.
post #6 of 23 Old 11-08-2011, 01:27 PM
DL700's Avatar
on trails and roads u really wont see enough load or heat in the motor to detonate on 89 octane maybe even on 87, but put a really fat guy on the bike or put it in the sand where engine load greatly increases then u will have problems,... and the cost is A LOT MORE then just a FEW CENTS a gallon....Detonation will most likely run piston, cylinder head and cylinder...maybe even the rod...
on the contrary too high of octane will Hurt power(on low compression motors), the higher fuel octane will take longer to release the BTU energy thus suffering from higher rpm loss of performance...
DL700 is offline
post #7 of 23 Old 11-08-2011, 06:38 PM
traitor08's Avatar
I always run 93 in all small engines.
MY RIDES
Amish washing the buggy^^^^
traitor08 is offline
post #8 of 23 Old 11-09-2011, 03:16 AM
AusTrx700xx's Avatar
We can't eveether 89here in Aus, our options are 91, 93 and 98, I'm stoked that for once Australia has acess to stuff that the U.S doesn't
All readyto roost thanks to
Mike at Quadparts.com.au
Team IMS imsproducts.com
George at MonsterLab Atv
Kimberly Motorcycles
Minshull Mechanical Repairs
AusTrx700xx is offline
post #9 of 23 Old 11-09-2011, 07:48 AM
traitor08's Avatar
We also have the option of 102 or 110 here
MY RIDES
post #10 of 23 Old 11-09-2011, 10:17 AM
09RappySE's Avatar
Quoted: 16 Post(s)
I would'nt go that far.....I have access to 87,89,91,93,100,110,114 within 3 local stations.....
734 09 Raptor
Tuned by EHS Racing 78hp 55Tq
09RappySE is offline
