sprocket recommendations for 20" tires - Club700XX - Honda TRX700XX Forum
post #1 of 19 Old 11-12-2011, 09:18 PM Thread Starter
Well I just installed a set of GBC x-rex tires(20x11x10rear and 21x7x10front) on my XX! Just wondering what set-up everyone with 20" rears are running with they're sprockets?? I dropped one tooth on the front when I was running my stockers, which is still whats on there now!! I havent got enough seat time yet to determine a opinion on this set-up with the 20s!! I mostly just trail ride with some occasional drag races!! So whats everyone running and how yall like it???
almost is offline
post #2 of 19 Old 11-12-2011, 09:20 PM Thread Starter
O yea I also have the big 3 on there too!!
almost is offline
post #3 of 19 Old 11-12-2011, 09:26 PM
I run the 14 tooth with my 20's but I have 60+ horsepower with my xx so that makes a big difference.
post #4 of 19 Old 11-12-2011, 09:50 PM
14T, I like it!
post #5 of 19 Old 11-12-2011, 11:03 PM
traitor08's Avatar
Stock
MY RIDES
Amish washing the buggy^^^^
traitor08 is offline
post #6 of 19 Old 11-13-2011, 07:38 PM Thread Starter
well I guess I'll put the stocker back on and try it then!
almost is offline
post #7 of 19 Old 11-14-2011, 01:07 AM
Qaz
yeah id say 14 also i run 13 and going back up since now i have exhaust and such
Qaz is offline
post #8 of 19 Old 11-14-2011, 01:03 PM
theyre only like 10 bucks a piece and theyre really easy to swap. I'd say try a few and see what works best for you and where you ride.
I ride a lot of really tight trails so im actually running a 12t. Its a little too small but I will be putting 23" or 24" tires on soon so that should even it out.
TxAggie09 is offline
post #9 of 19 Old 11-14-2011, 01:27 PM
I'd say to go back to the 14t... perhaps even a 15t. You could try both for little $$ and see what works best for YOU. What others like and what works best for them may not be what is right for you, the type of riding you do and where you ride.
post #10 of 19 Old 11-14-2011, 07:51 PM Thread Starter
yea from what little i've rode it, it seemed to not pull as hard through 3rd and 4th with the 13tooth and 20"s I think I'll go back to the 14!! I dont have anyone around here to compare to in drag races to see which one would be the fastest in a drag race, I know on my old 400ex i was faster at the dunes with a minus 2 teeth on the front than a minus 1 tooth because i could do some 2nd gear starts, on the trails I would go back to a minus 1 tooth just seemed to pull harder and was more fun!! I just need a couple of of off days to get it figured out!!
almost is offline
