Hard to get in GEAR HELP - Club700XX - Honda TRX700XX Forum
post #1 of 6 Old 11-18-2011, 09:39 PM Thread Starter
pissed Hard to get in GEAR HELP
Noise on right side when i shift gears sitting idle hard to get in gears sometimes. Netural almost impossible to get in when running. Will go right into netural with engine not running. Can any one help. Any transmissions problems out there. Something to do with right amount of oil.
08 trx700 upgrades, fmf tuner, lexx slip on. K&n mod. No lid. No arreestor in exhaust. 20" razar on back.23 in front. 13 tooth front. 11/16 l8 sway bar
04 kfx 700 pro armor nerf bars. Armadillo bumper. White Polaris spring.
110 CC China junk
dantheTRXman700 is offline
post #2 of 6 Old 11-19-2011, 06:05 AM
traitor08's Avatar
Sounds like clutch maybe. If it shifts fine off, but not good running, clutch might be dragging a little. Does bike try to move or jerk any while idling in gear with clutch pulled?
MY RIDES
Amish washing the buggy^^^^
traitor08 is offline
post #3 of 6 Old 11-19-2011, 08:49 AM
headscratch
you may have too much freeplay in the clutch cable, causing clutch not to engage fully when pulled in. i like mine with 1/8 of freeplay or a smudge tighter.
post #4 of 6 Old 11-19-2011, 09:08 AM
traitor08's Avatar
Disengage
MY RIDES
post #5 of 6 Old 11-19-2011, 03:11 PM
dantheTRXman700,
I agree completely with tbird88. Probably a simple clutch adjustment. Look at your manual if you have any concerns about the dimensions but tbird is right on.
post #6 of 6 Old 11-19-2011, 06:10 PM
dantheTRXman700,
If this doesn't work then I would check the the shifter shaft linkage inside the motor. Its a PITA to get to ,as you have to remove the clutch basket. Chances are you may have bent it. Try the easy stuff first.
