Auto Decompression on the 700xx - Club700XX - Honda TRX700XX Forum
post #1 of 58 Old 11-21-2011, 05:12 PM Thread Starter
How does the it work? Anyone have pictures of the pieces to it? Could it wear out?
post #2 of 58 Old 11-21-2011, 08:30 PM
skier207's Avatar
Yes it could wear out/malfunction. Check your compression if it is higher than what the manual states (65 psi I think)I would first adjust your valves and recheck. Your valve adjustment is off it can effect the compression release operation (thanks DL). Always check your compression with the throttle open.
It looks sort of like a cam lobe. It has a low tension spring that holds it in the up position. It also has a counterweight opposite the lobe. While cranking the lobe is held in the up position by the spring and it locks in place by the drag of the rocker arm. It bleeds off some compression by slightly opening the exhaust valve while cranking. Once the engine starts the centrifugal force on the counterweight opposite the lobe deactivates it.
skier207 is offline
post #3 of 58 Old 11-21-2011, 09:59 PM Thread Starter
I'm wondering if this is where my "noise" is since this is exactly where it sounds like it is coming from and it really only happens when my XX is idling.
post #4 of 58 Old 11-22-2011, 08:01 PM
Can the cam lobe tension spring brake or fall off. Cant find a cam parts brake down? Have a loud noise in motor when the bike is hot. Also adj valves other noise whent away. When i had valve cover off found decomp. Cam flopping on the shaft is that normal? Thanks
Bigrich is offline
post #5 of 58 Old 11-24-2011, 01:45 PM Thread Starter
I just found out my bike has 100psi on a compression when it should be 65psi. I think this is the course of my noise! Bike is also sometime hard to start as if the clutch wasn't completely releasing. Makes total sense!
post #6 of 58 Old 11-24-2011, 09:07 PM Thread Starter
What i can't figure out (cause i haven't seen it with my own eyes) if i need to replace this - what parts actually need replaced?! Do I need a new cam!?
post #7 of 58 Old 11-25-2011, 07:52 PM
skier207's Avatar
I don't think the decompresser comes separate. I bought a used Webb cam and it came with the decompresser. I think mine hangs up at times I may have to take the one off the stock cam.
skier207 is offline
post #8 of 58 Old 11-25-2011, 10:22 PM
headscratch
mine hangs up especially when i stall it and then on refire. thats when its actin up. it doesnt hang up unless you stall it under a load..
post #9 of 58 Old 12-13-2011, 08:49 PM Thread Starter
So no one has a picture of a stock cam with the decompressioner on it!?
post #10 of 58 Old 12-13-2011, 08:55 PM
boost addict's Avatar
I will post a pic of a stock cam with the decompressioner on it tomorrow. I have 2 of them if you need one.
The best in the business
Bo White 205-886-7043
Ed @
Chris & Mike
boost addict is offline
