New Exhaust Wont Start HELP!!! - Club700XX - Honda TRX700XX Forum
post #1 of 17 Old 11-27-2011, 02:32 PM Thread Starter
Hello,
I picked up a 2008 TRX700XX is super clean and ran great i put an exhaust on quad and now it will not start? When i got done installing the exhaust, i unhooked battery and tried firing it up, two back fires and then just ran battery down. Do I need a fuel controller or what?? I figured I may need one but I thought it would at least start?? HELP!!!
Wayne
wbwayne00 is offline
post #2 of 17 Old 11-27-2011, 06:26 PM
wbwayne00,
Fuel is on-- right? Petcock on left side under the tank is in on position--right?
Kill switch --off position--right?
Disconnected the battery--why? Need battery to operate the fuel pump and injection system.
Try some of these things before spending big bucks
post #3 of 17 Old 11-27-2011, 06:27 PM
It should start?
post #4 of 17 Old 11-27-2011, 06:55 PM Thread Starter
Well I have not checked the fuel line....I have not even ridden the quad except off the trailer into my storage area, and put the exhaust on..If it is the fuel being off I am going to kick myself in the a$$!! Heck I am going to the office now to check it...
Wayne
post #5 of 17 Old 11-27-2011, 07:50 PM Thread Starter
Checked the petcock it is on, when it is turning over after cranking on it awhile it smells of gas, I am not giving it any throttle or anything due to the fuel injection. It sure as heck seems as if there is for sure no fire at all now. I sprayed off the dust from wheni bought it with a pressure washer plugged up exhaust and intake is there something that could of shorted out? I am at a loss??? any ideas that I could check oiut would be appreciated thanks in advance.
Wayne
post #6 of 17 Old 11-27-2011, 09:25 PM
wbwayne00,
Is the gasoline fresh? Check that if that is the original gasoline it will smell somewhat like turpentine. Very Bad!!!! Fuel system must be cleaned. Drain system and try fresh gasoline. Could be a wet spark plug from the cranking if the gasoline is not spoiled. You power washed after purchase. Pressure washing is sometimes not desirable due to infiltration into delicate circuits but regular washing is OK. Check to make sure the kill switch is in the off position. What about the air cleaner? You didn't mention looking at it. I've seen mouse nests in the air box after long term storage.
Check oil level. It may look like it needs oil but don't be alarm these machines, with the dry sump are difficult to check for oil level. The engine needs to be run for a while to pump the oil from the crankcase back into the oil reservoir.
Backtrack the installation of the exhaust system to make sure no wires were inadvertently disconnected.
Please keep us updated
post #7 of 17 Old 11-27-2011, 09:52 PM
AusTrx700xx's Avatar
Have you cleaned or re oiled the filter at all? Caus I had a similar problem once, bit it was due to the type of spray oil I used on the filter, also check that the temp sender in the air box is clean.
All readyto roost thanks to
Mike at Quadparts.com.au
Team IMS imsproducts.com
George at MonsterLab Atv
Kimberly Motorcycles
Minshull Mechanical Repairs
AusTrx700xx is offline
post #8 of 17 Old 11-28-2011, 07:29 PM Thread Starter
Airbox is clean, Gasoline is fresh, I smell fuel I am leaning towards a bad spark plug. I have not even pulled it yet but I will pick one up on the way in tomorrow.
I will update when i get this thing going..
Wayne
post #9 of 17 Old 11-28-2011, 08:59 PM
RaVxX's Avatar
You said you put a exhaust on, it come new, you sure there isn't anything stuck in the header pipe or tail pipe clogging it up bad ? That would cause it not to start.
_______________________________________________
08 Red & Black 700XX
15T, Open Air Box w Uni, full HMF, PCIII, Kenda Kutters Front and 50lbs worth of Super Swamper Vampires in the back.
11 Can-Am Renegade 800R
HMF Slip on, ITP SS108 wheels w/ 27" Zillas, Stage 1 Elka's, ATV 4 Play Soft Bars.
RaVxX is offline
post #10 of 17 Old 11-28-2011, 09:09 PM
One of the first things to check every time, IMO.
