11 to 1 Piston and Hot Cams Stage 3 - Club700XX - Honda TRX700XX Forum
post #1 of 6 Old 12-16-2011, 01:50 PM Thread Starter
Redline700xx's Avatar
Thinking about getting a couple new parts. 11to1 piston and a stage 3 cam. Just wondering if you can run a stage 3 without changing anything else? Also should this setup run on pump gas? What kind of gains should I see? Have EHS Big 3 already. Thanks for the help guys...
2008 700xx
K&N Filter
Kenda Kutter XC Tires
EHS Big 3
AMR Graphics
L8TON 9/16" Sway Bar(New Model)
Honda Racing Aluminum Skid and A Arm Plates
Honda Racing Aluminum Grab Bar
Redline700xx is offline
post #2 of 6 Old 12-16-2011, 02:12 PM
08700xx's Avatar
Yeah you can run that setup without changing anything else. You'll be fine to run that setup with 91 octane or higher (pump gas) I am going to guess you'll see about 3-4HP adding the HC3 and the 11:1 piston.
(DL700)
Jody (Boost Addict)
08700xx is offline
post #3 of 6 Old 12-16-2011, 03:11 PM
Your programming will need to be changed on your fuel controller for the cam.
post #4 of 6 Old 12-16-2011, 07:15 PM
08700xx's Avatar
Eric from EHS will be able to tell you what to do with that but Im sure it will be adding 1/2-1 more fuel with the + button (just my guess, ask Eric to be sure)
(DL700)
Jody (Boost Addict)
08700xx is offline
post #5 of 6 Old 12-16-2011, 09:25 PM
I forget the settings but I would guess they are close to the ones I have at home. You'll feel a real nice boost in power. I was on a stock piston with just hc3 in my sand dunes vid and my most recent against the yellow raptor
post #6 of 6 Old 12-18-2011, 11:26 AM
TRX700XX's Avatar
I have a pretty good dobeck map for that setup.... msg me for it
TEAM TORQUE RACING
2009 TRX700XX
TRX700XX is offline
