Small starting problem - Club700XX - Honda TRX700XX Forum
post #1 of 5 Old 12-18-2011, 05:54 PM Thread Starter
This issue only came up in the last day or so. When the bike is warmed up it gets very hard to restart while in gear. Even with the clutch in, it still lurches forward just a bit when the starter is hit (it doesnt keep moving forward, it just jumps a bit then the engine starts turning over). It also starts much better when in neutral.
Is this normal or do yall think that the clutch isnt fully engaging, or is worn out?
It was also really hard to start today when it was colder out. And same deal, it lurched forward when the starter was hit.
TxAggie09 is offline
post #2 of 5 Old 12-18-2011, 05:59 PM
You just need to adjust your clutch I think.
post #3 of 5 Old 12-18-2011, 06:33 PM
traitor08's Avatar
Clutch isn't disengaging, tighten cable some.
MY RIDES
Amish washing the buggy^^^^
traitor08 is offline
post #4 of 5 Old 12-19-2011, 08:22 AM Thread Starter
ok thanks, ill give that a try
post #5 of 5 Old 12-19-2011, 04:28 PM
There's a post about this somewhere. I'll try and find but to me this is normal. Done it with every Honda ,I have owned even a couple of other breeds.Both 2 and 4 wheelers. Please don't run the clutch cable too tight. You need some play in the cable or a new clutch shortly after.
