K&N Airfilters - How do you clean them?! - Club700XX - Honda TRX700XX Forum
post #1 of 14 Old 03-24-2009, 08:40 PM Thread Starter
I just checked my K&N and is BEYOND dirty. Last time I rode it was so dusty, i should have been wearing a respirator! That made the filter FULL of dirt/dust so that it turns into mud and doesn't seem to get any cleaner. Anyone know how to get it super clean!?
post #2 of 14 Old 03-24-2009, 10:27 PM
post #3 of 14 Old 03-25-2009, 07:05 AM
Killer_Shee's Avatar
I have never had a problem getting a K&N clean, no matter how dirty. Just soak it with the K&N cleaner and let it sit for 20-30 mins. Then wash it out with a garden hose from the inside out.
Killer_Shee is offline
post #4 of 14 Old 03-25-2009, 07:42 AM
I use the Modquad setup that has the filter bag that goes over the K&N. It seems to work very well at keeping the bigstuff out of the K&N. I got it at Rocky Mountain ATV and I think it was about a 100 dollars for the whole setup but I'm sure you can order the filter bag seperate. I have the same filter setup on my wifes 400EX.
Colorado 700XX is offline
post #5 of 14 Old 03-25-2009, 09:44 AM
xx-rated's Avatar
Get an Outerwears pre-filter. You should be able to find one at Rocky Mtn pretty cheap. If you are using a gauze type filter, I highly recommend a pre-filter when you ride in dusty conditions.
xx-rated is offline
post #6 of 14 Old 03-25-2009, 11:05 AM Thread Starter
Thats the thing... I even had that on there too!
post #7 of 14 Old 03-25-2009, 12:55 PM
Well, at lest you know the K&N is working. If you were running some cheap filter all that dirt might have made it into your motor.
post #8 of 14 Old 03-25-2009, 12:58 PM Thread Starter
I'm actually going to take the filter off and look at the throttle body blade after seeing Gary's (scuzz) posts about other K&Ns
post #9 of 14 Old 03-25-2009, 01:23 PM
While we're talking about filters and stuff I found something funny the other day.
After each ride I clean and oil my air filter and change my oil. Prior to this past ride I put a new plug in my quad, fired it up and checked it to make sure that it wasn't running rich. When I pulled the plug out it was covered in oil!
Turns out it wasn't my rings but that I hadn't got all the oil out of the air filter when I cleaned and re-oiled it.
D'oh!
post #10 of 14 Old 03-25-2009, 01:38 PM Thread Starter
D'oh!
Think you might be using too much oil?
