In-gear starting, and reverse limiter - Club700XX - Honda TRX700XX Forum
post #1 of 4 Old 01-05-2012, 12:37 AM Thread Starter
OK, so I decided to wrap two threads into one.
First, I don't remember ever having to be in neutral to start this quad, and suddenly I have to be. Is this normal, or am I imagining things??
Second, how do I disable the reverse rev limiter? I hate it.
Thanks all
S2K_Driver is offline
post #2 of 4 Old 01-05-2012, 01:58 AM
08700xx's Avatar
The XX has a problem starting in gear for some crazy reason, mine does the same thing once it gets hot.
heres the link for the rev limiter.
https://www.club700xx.com/vb/showthread.php?t=2312
(DL700)
Jody (Boost Addict)
08700xx is offline
post #3 of 4 Old 01-05-2012, 08:14 AM
AusTrx700xx's Avatar
On the 700xx they have a clutch switch, so you can turn it over in gear with te clutch pulled in, or if you have a aftermarket clutch lever you have to join the wires together,
All readyto roost thanks to
Mike at Quadparts.com.au
Team IMS imsproducts.com
George at MonsterLab Atv
Kimberly Motorcycles
Minshull Mechanical Repairs
AusTrx700xx is offline
post #4 of 4 Old 01-05-2012, 10:23 AM
I highly recommend getting rid of the reverse limiter too. I hated backing up a hill or out of some mud and the darn thing dies when you give it some gas. Its an easy fix and well worth it.
trail toy: '09 700xx: trailtech vapor, trailtech X bars, trailtech riser, OURY grips, l8ton 9/16" XL swaybar, CCP Stabilizer, 23" Razr front,24" bearclaws rear, fmf q4 slip-on, EHS programmer, EHS lid, powermadd handguards, Honda Racing skids, PRM 6 pack rack, 6000k HID's
lake toy: 98 Kawasaki ZXI 1100 jet ski, mostly stock
big toy: 2011 GMC 2500 duramax CCLB 4x4, a few mods but mostly stock
TxAggie09 is offline
