clutch problem? - Club700XX - Honda TRX700XX Forum
post #1 of 8 Old 01-08-2012, 07:30 PM Thread Starter
clutch problem?
My trx700 after running awhile 20 minutes or so. Starts to make a loud clunking noise. And next to impossible to get in neutral. Do I need a clutch kit or just spring. Or something else. And what clutch kit should I get. Thanks for any help.
08 trx700 upgrades, fmf tuner, lexx slip on. K&n mod. No lid. No arreestor in exhaust. 20" razar on back.23 in front. 13 tooth front. 11/16 l8 sway bar
04 kfx 700 pro armor nerf bars. Armadillo bumper. White Polaris spring.
110 CC China junk
dantheTRXman700 is offline
post #2 of 8 Old 01-08-2012, 08:56 PM
EHS has a clutch kit that is around $80, if you're stock you wont need to change to heavier springs. Just need new fibers if that is what is wrong. Are you out of adjustment? www.ehsracing.com
post #3 of 8 Old 01-09-2012, 05:10 AM Thread Starter
Upgrades big 3, 13 tooth front sprockett, what do you mean by adjustment, cable adjustment, I have never have touched, problem started when drag racing.worked fine for two years. With factory clucth.
From day one bike was hard to get into neutral. While it is running. But now the clunking noise and so hard to get in gear.
110 CC China junk
post #4 of 8 Old 01-09-2012, 06:05 AM
AusTrx700xx's Avatar
I would Pull your clutch cover off and have a look at it, I have seen a similar problem on a crf450 and it turned out to be a broken clutch basket/spring retaining bolt,
All readyto roost thanks to
Mike at Quadparts.com.au
Team IMS imsproducts.com
George at MonsterLab Atv
Kimberly Motorcycles
Minshull Mechanical Repairs
AusTrx700xx is offline
post #5 of 8 Old 01-09-2012, 07:12 AM
The clutch cover is easy to remove. You might want to investigate. I was saying make sure your clutch cable isn't out of adjustment. From what you say it sounds worse than that. Pull the cover and check everything like stated above.
post #6 of 8 Old 01-09-2012, 07:23 PM Thread Starter
Pulled clutch cover and basket seems wabble? Seems like bad bearing
maybe. Surprised im having problems out of my Honda. Any one else with same problems. And what else should I look forward to going wrong.
110 CC China junk
post #7 of 8 Old 01-09-2012, 07:34 PM
All of the xx's have loose clutch baskets even when new, mine has some play in it as well and makes a little bit of a whine. I will be replacing my basket soon with something else, as soon as I can verify that it will fit.
post #8 of 8 Old 01-10-2012, 04:12 PM Thread Starter
Let me know if you find one that works. Clutch basket gone. That's the loud clunk.
110 CC China junk
