My Cam Change - Club700XX - Honda TRX700XX Forum
post #1 of 13 Old 01-17-2012, 09:34 PM Thread Starter
My Cam Change
This was actually alot easier than I thought it would be and really only took about 1.5 hours to get the cam out. At the time of this writing, I haven't put it back in yet but... we'll see. I started taking pics after I had the fuel tank and everything it takes to get it off - off. So here you go. The blue arrow in the last pic is the decompressioner and why I changed cams to begin with and yes, I am replacing it with a stock cam (Thank you very much Jude - nm700xx.) I will be putting it back together tomorrow night. Is there anything I need to know first?
Hint: when doing a cam change - you dont need to drain the gas, just turn the valve to the off position. lol
post #2 of 13 Old 01-18-2012, 05:06 PM
Since you are already that far, you should just toss in a Hot Cam 3. Cheap easy power since you are already that far
post #3 of 13 Old 01-18-2012, 05:18 PM Thread Starter
I thought about it, but I dont have ANY other performance mod. That would require, intake, tuner, full exhaust... another $1000 worth of shit. I'm pretty happy with the power I have so I just put a stock cam back in.
post #4 of 13 Old 02-02-2012, 09:35 AM Thread Starter
New cam didn't fix anything. Only thing not replaced is the cam chain itself. I guess that's next. Anyone have a how to? Or How much more of the motor needs to be taken apart?
post #5 of 13 Old 04-16-2012, 08:56 AM Thread Starter
For future readers - I ended up replacing the cam chain. Fixed everything.
post #6 of 13 Old 04-25-2012, 11:58 PM
What was the problem?
fraiolib is offline
post #7 of 13 Old 04-25-2012, 11:59 PM Thread Starter
ding ding ding....
now i'm tearing it all back apart again for the HC3
post #8 of 13 Old 04-26-2012, 12:01 AM
Lol no.... I mean y were u fixing it... What was it doing?
fraiolib is offline
post #9 of 13 Old 04-26-2012, 08:09 AM Thread Starter
It was making this ticking noise. I originally thought it was a decompressioner so i switched out cams - still there. Then I had a new cam chain installed and that fixed it. Technician said even with the cam chain adjuster there, you could pick the chain off the top of the sprocket! I'm just glad it didn't jump time and destroy the engine.
This should have all been fixed THE RIGHT WAY when I took it to the dealer a year and a half ago - when it was still under warranty no less for this noise and they rebuilt the motor and charged me for it. Still ticking away when I got it back. You would've thought they would've put a new cam chain in on a rebuild, pretty sure they just did rings and bearings on it though - piece of shits.
post #10 of 13 Old 04-26-2012, 09:17 AM
well boys and girls we've learned a valuable lesson from this. If you want it fixed right you do it yourself! haha j/k Glad you got it fixed Swope
