Broke Coil Wire - Club700XX - Honda TRX700XX Forum
post #1 of 8 Old 01-17-2012, 09:46 PM Thread Starter
Broke Coil Wire
Wire pulled out of the sparkplug boot.... do I have to buy a whole new coil now!? It looks like it's all one piece and it certainly doesn't want to come apart from the coil itself.
It would be parts 2 and 3.
post #2 of 8 Old 01-18-2012, 09:22 AM
WILDMANNUM1's Avatar
The spark plug boot should screw back onto the wire
WILDMANNUM1 is offline
post #3 of 8 Old 01-18-2012, 10:18 AM Thread Starter
So just stick the wire back in the boot and screw it back in?
post #4 of 8 Old 01-18-2012, 11:11 AM
Yep, that's the way most are assembled.
2006 Raptor 700
post #5 of 8 Old 01-18-2012, 04:59 PM
If the copper wire is still showing in the coil/black wire piece you are fine and can just screw the boot back on. If the wire broke higher then you are out of luck. They dont give you any extra slack to play with and will need a new coil. I hope this answers your question. I had the same thing happen to me and had to buy a new coil
post #6 of 8 Old 01-18-2012, 05:23 PM Thread Starter
This is stupid. Should have made a typical coil. Could this be converted to a coil with a plug end on it so that we could possibly use normal sparkplug wires?
post #7 of 8 Old 01-18-2012, 06:39 PM
Brokenbones's Avatar
Maybe a 450r would fit?
Brokenbones is offline
post #8 of 8 Old 01-18-2012, 07:29 PM
TRX700XX's Avatar
i just shoved it back in and filled the boot lip with silicone
TEAM TORQUE RACING
2009 TRX700XX
TRX700XX is offline
