Dual Exhaust on my 700xx - Club700XX - Honda TRX700XX Forum
post #1 of 10 Old 01-18-2012, 01:47 AM Thread Starter
So if you're paying attention, I have my quad apart right now... Entire exhaust is off as well. I'm looking around and i'm PRETTY SURE I could put duals on it, with a little bit of custom pipe. It would have to come from a single pipe, then "Y" off to duals but...
My original unorthodox way was with a single 07 GSXR pipe as seen below.
Now i'm thinking I can come up under the airbox, through the chain and up over the frame rail to the other side. I think my questions are... what do you think of 2 mufflers this same size will do for performance? Sound? Efficiency? I know one thing... that single short muffler was pretty freaking loud. You could hear me from a LONG way off, i'm not opposed to using longer mufflers, other manufacturers, even stock mufflers off a sport bike, but i'm pretty sure this could be done fairly easy. What do you guys think?
post #2 of 10 Old 01-18-2012, 07:59 PM
I am trying to do something similar. If you know someone with a Twin pipe CRF250r, that's what I basing the idea on. 2-1-2 , my way of having a full power and 94dbs. That's the plan.
post #3 of 10 Old 01-19-2012, 09:18 AM Thread Starter
How would it be 2-1-2 when it starts off with a single exit exhaust? Wouldn't it just be 1-2?
post #4 of 10 Old 01-19-2012, 10:26 AM
Brokenbones's Avatar
He use a dual port xr head ;)
Brokenbones is offline
post #5 of 10 Old 01-19-2012, 10:37 AM
I bet you noticed the crf have a smaller exit on one silencer: the left side is longer than the right side so this is for balancing flow.
post #6 of 10 Old 01-19-2012, 05:39 PM
Correct !
I did notice this but if I can make it work with the "RR"( XR head) then I'll make it fit the "XX"
It involves a new airbox and some stuff.
post #7 of 10 Old 01-19-2012, 07:11 PM
Oh yeah i'm in the thinking of this because of the same reason, noise restriction here we get 150$ ticket...I thought of battery relocation and shorten the intake tube. By the way ltr450 people use crf throtle 50mm http://www.kmsperformance.com/shop/item.aspx?itemid=4, so I just can believe no one here tried it:/
post #8 of 10 Old 01-20-2012, 12:25 AM Thread Starter
Correct !
I don't believe you. Pics or it doesn't exist.
edit: since this is my thread, i'll allow a LITTLE off topic.
post #9 of 10 Old 01-20-2012, 04:12 AM
Become platinum and you will the ''note from the padded cell' thread by Baxter lol
post #10 of 10 Old 01-21-2012, 12:40 AM Thread Starter
Done ;)
