Has to be pull started - Club700XX - Honda TRX700XX Forum
post #1 of 8 Old 01-30-2012, 05:49 PM Thread Starter
POPMAN700XX's Avatar
my fully stock 700 has just recently been messing up. It has always had a slow start to it, but recently acted as if the battery was going dead. It would start when jumped, and would start after it was warm. Now, however it will not start at all by the switch. It turns the starter but acts as if the compression is to high to turn the motor over. it will start when dragged. when its cold, it will blow black smoke as if it's flooding itself. once warm, it runs great, but still has to be pull started. could it be valves, decompression switch, Cam?
POPMAN700XX is offline
post #2 of 8 Old 01-30-2012, 08:15 PM
TRX700XX's Avatar
battery is weak! if these engines dont turn over fast enough they flood out.... get new battery from wally world or ebay for cheapest
TEAM TORQUE RACING
2009 TRX700XX
TRX700XX is offline
post #3 of 8 Old 01-31-2012, 01:51 PM
I can leave mine outside in the cold for 5 weeks with a datatool 4 alarm active and it will still start straight away.
Stall it when out riding, push the starter and the same symptoms as described above happen, its like the starter is not quite powerfull enough?
It has always been like this.
rappey is offline
post #4 of 8 Old 01-31-2012, 03:52 PM Thread Starter
It has a brand new battery in it....that's what I thought the problem was. got a 165 cranking amp motobatt online. The old battery checks out good also.
post #5 of 8 Old 01-31-2012, 05:08 PM
BuckeyeXX's Avatar
Mine used to do that when it warmed up when I first bought it but I haven't noticed it lately.
08 700XX Black/Gray
01 90 Yerf Dog
BuckeyeXX is offline
post #6 of 8 Old 02-07-2012, 01:35 PM
Booser001's Avatar
Check the valve clearances
Booser001 is offline
post #7 of 8 Old 02-20-2012, 02:31 PM
I just did some mods to mine and now I am having the same issue. After putting in an 11:1 piston, stage 1 cam exhaust, programmer and air filter. It was running fine for the first two times I took it out and now it won’t even jump start. I can pull start it and it runs great but if I shut it off I got to get pull started again. There is a ticking noise at the top where the cam is so I think I need to replace the auto-decompression mechanism. I can’t find anyone that sells just the auto-decompression mechanism. Don’t want to buy the stock cam just for the auto-decompression mechanism and find out that is not the problem
fladehoff is offline
post #8 of 8 Old 02-22-2012, 09:47 PM
quadmonkey700xx's Avatar
possibly need to rebuild starter, not sure but its cheap to do
quadmonkey700xx is offline
