Tension Stopper - Club700XX - Honda TRX700XX Forum
post #1 of 5 Old 02-05-2012, 04:01 PM Thread Starter
Tension Stopper
Hrmmm Working my way down the Manual for removing head.
Asking me to remove cam chain tensioner lifter bolt and sealing washer. ok easy enough.
Then it says to rotate the tensioner shaft clockwise fully and stop it with the "special tool"
wtf do i get one of those.....
fhibbs12 is offline
post #2 of 5 Old 02-05-2012, 04:04 PM
skinny screw driver, but you only really need to do that when reinstalling the tensioner. just take the two mounting bolts out and pull the tensioner out, two 8mm head bolts i think
post #3 of 5 Old 02-05-2012, 04:40 PM Thread Starter
cylinder head cover.... wtf is the trick.
fhibbs12 is offline
post #4 of 5 Old 02-05-2012, 06:46 PM
Take all the bolts out and then bump the side of the cover with a dead blow hammer to break it loose there isn't a gasket for the head cover it's just siliconed to the head
post #5 of 5 Old 02-05-2012, 09:17 PM Thread Starter
Yeah the cover definately took some persuasion to get off.
fhibbs12 is offline
