Whats the best clutch for a trx700xx - Club700XX - Honda TRX700XX Forum
post #1 of 8 Old 02-05-2012, 10:12 PM Thread Starter
I have the 727 kit what is the best clutch for drag racing
727xx is offline
post #2 of 8 Old 02-05-2012, 10:59 PM
Replace the semi fiber clutch disc with a full fiber disc, pull the judder springs and replace three of the six clutch hub springs with heavier ones and you will be good to go. There are not very many options when it comes to clutch parts for the xx.
post #3 of 8 Old 02-05-2012, 11:12 PM Thread Starter
Ok where can i buy it ???
727xx is offline
post #4 of 8 Old 02-05-2012, 11:25 PM
08700xx's Avatar
Pm DL700 he has a kit he sells
(DL700)
Jody (Boost Addict)
08700xx is offline
post #5 of 8 Old 02-05-2012, 11:35 PM Thread Starter
I have the same bulid you have but i only have 12.5.1 piston on 110 mix What is the best a/f ratio for these trx700 and thank u for the clutch
727xx is offline
post #6 of 8 Old 02-06-2012, 08:20 AM
valk680's Avatar
Check e-bay there are few on there. I just got the one from Driveline performance. No rides on it yet. It seems to be high quality and it was only $72.00 shipped.
715 11:1 big bore
+1 intake valves
Sredrums +3 throttle body
PCV
NGK BKR6EKPB-11 spark plug
K&N air filter w/outerwares,
Barker exhaust
PBI sprockets /D.I.D chain
Stage 3 Elka's on all 4 corners
valk680 is offline
post #7 of 8 Old 02-06-2012, 03:09 PM
You can actually buy everything from your local Honda dealer also, just make sure you get the correct fiber. (Not the part number with a quantity of one, it is the part number with a quantity of 6 I believe.) The fibers used in the TRX450R are the same part number as the 700XX ones, so I already had a few extra fibers laying around.
As for springs, I also used what 450R guys are using, CR500 springs. The part numbers of the springs are also the same between the 450R and 700XX and I know alot of people who use CR500 springs as heavy duty springs in their 450R, so figured I would give it a shot in the 700XX also. (I just ordered 2001 CR500 springs, but I think they have been the same for the last decade the CR500 was produced.) I ordered 6 CR500 springs, but not exactly sure how many I will use yet, will experiment some to see how stiff the clutch lever gets.
Haven't had a chance to try the clutch yet, motor has been apart getting some work done, hopefully I will have it back together in a couple more weeks.
Doug
2004 TRX450R, 2008 TRX700XX
2005 TRX450R
1986 TRX250R
D Bergstrom is offline
post #8 of 8 Old 02-12-2012, 11:56 AM
I put the driveline clutch in from ebay as well and so far works great! it is better than the stock so far...
Rhinoman50 is offline
