Top End Tear Down - Club700XX - Honda TRX700XX Forum
post #1 of 12 Old 02-11-2012, 04:11 PM Thread Starter
Top End Tear Down
Is this normal looking?
fhibbs12 is offline
post #2 of 12 Old 02-11-2012, 04:12 PM Thread Starter
I was getting ready to get some work done and seen this and got worried....
Is this normal? Should I not invest the money into piston/port work?
fhibbs12 is offline
post #3 of 12 Old 02-11-2012, 04:48 PM Thread Starter
Piston
fhibbs12 is offline
post #4 of 12 Old 02-11-2012, 05:09 PM
traitor08's Avatar
If the compression is good the rings are fine. The piston is ok. Id do headwork since its off. Hell since its apart put a high comp piston in it and cam. How do the clinder walls look. Any crosshatch?
MY RIDES
Amish washing the buggy^^^^
traitor08 is offline
post #5 of 12 Old 02-11-2012, 05:23 PM Thread Starter
I work on computers for a living not engines so just getting this far made me happy lol. First time ever opening up an engine.
So I have no clue about crosshatch. I will go take another photo though.
fhibbs12 is offline
post #6 of 12 Old 02-11-2012, 05:27 PM Thread Starter
fhibbs12 is offline
post #7 of 12 Old 02-11-2012, 05:27 PM Thread Starter
hoprfully that image shows you what you need to see
fhibbs12 is offline
post #8 of 12 Old 02-11-2012, 06:03 PM
traitor08's Avatar
Your cylinder and consequently ring and piston should be fine. There is still crosshatch pattern in there. See the fine lines inside the look like real fine scratches. The make a lattice pattern on your cylinder walls. The helps with sealing the combustion chamber. Its when you see scratches or score marks going up and down the cylinder when you have problems.
MY RIDES
post #9 of 12 Old 02-11-2012, 06:07 PM Thread Starter
Good deal going ahead as planned ty :-)
fhibbs12 is offline
post #10 of 12 Old 02-11-2012, 06:31 PM
traitor08's Avatar
Take your fingernail and see if there is a ridge on the side the head bolts to, also just rub around in cylinder and see if you feel any scratches. Just to double check. Just remember, we are looking at pictures and can't see everything.
MY RIDES
