How much of the motor has to come off to replace a cam chain? - Club700XX - Honda TRX700XX Forum
post #1 of 19 Old 02-18-2012, 02:01 AM Thread Starter
Very simple. How much of the motor has to come off to replace a cam chain?
post #2 of 19 Old 02-18-2012, 06:54 AM
traitor08's Avatar
I could be wrong, but I believe you need to take the head, cylinder off then split the case.
MY RIDES
Amish washing the buggy^^^^
traitor08 is offline
post #3 of 19 Old 02-18-2012, 08:25 PM
Shouldn't be near that involved. Just by looking at the manual and my own torn down quad, I would say just the cylinder head cover and the clutch side (right) engine cover. Cylinder head cover should get you to the cam to get the top of the cam chain, the removing the right side cover should get you to the lower part of the cam chain. Should then just be a matter or pulling the old chain out of the motor and snaking the new one in. Of course, that is the simplified version, would need to do a bunch of little stuff, drain oil, remove cam chain tensioner, etc. Of course, haven't done it myself yet, so maybe it is harder then I am thinking.
Doug
2004 TRX450R, 2008 TRX700XX
2005 TRX450R
1986 TRX250R
D Bergstrom is offline
post #4 of 19 Old 02-18-2012, 08:33 PM
boost addict's Avatar
I am 99% sure you have to split the cases.
The best in the business
Bo White 205-886-7043
Ed @
Chris & Mike
boost addict is offline
post #5 of 19 Old 02-18-2012, 10:57 PM
Was out in the garage a little bit ago and happened to take a peak at my 700XX. (Currently everything from the cylinder up is off of it.) Cam chain does not even go into the center cases, it is out side of them, so no reason to split the cases. Just need to remove the right side engine cover and you will have full access to the lower portion of the cam chain. Only problem is, after looking at it, I don't think you can get that right side cover off with the motor in the frame, it is pretty close to the frame rail itself, at a minimum have to pull all the motor mount bolts and anything else holding the motor in place (intake, rad hoses, etc.) so you can shift the entire motor some to get room to pull that cover. Not really difficult to do, but would for sure take some time.
Doug
2005 TRX450R
1986 TRX250R
post #6 of 19 Old 02-20-2012, 04:16 PM
Doug...You are correct. Just the right side has to come off. I stopped by my shop at lunch and looked at it again(head & cylinder is off). Sorry for the confusion
Ed @
Chris & Mike
post #7 of 19 Old 02-20-2012, 04:24 PM Thread Starter
If I don't have to split the case, I think I can do this. There's a motor on ebay for $1500, I wonder if i'd be better off swapping it in and just building my current one up
post #8 of 19 Old 02-20-2012, 04:28 PM Thread Starter
I literally just walked out to the garage to see the right side only to find no quad in my garage. Guess I forgot it's at the dealer right now. Doh!
post #9 of 19 Old 02-20-2012, 04:42 PM
Very funny !
post #10 of 19 Old 02-20-2012, 04:42 PM
I never have had to replace mine. Both are still tight and look good!
Ed @
Chris & Mike
