whistling noise from exhaust - Club700XX - Honda TRX700XX Forum
post #1 of 12 Old 02-18-2012, 01:36 PM Thread Starter
Just picked up my ride, and after starting reved it a few times and the exhaust makes a whistle sound whenever I release the throttle. Bike has fmf 4.1 I believe, and power bomb header. Backfires a lot too
No programmer,....the likely cause?
B09XX is offline
post #2 of 12 Old 02-18-2012, 02:07 PM
yea get a programmer on it before you do some real damage.
post #3 of 12 Old 02-18-2012, 06:44 PM
Pinto's Avatar
x2, you are probably very lean.
Pinto is offline
post #4 of 12 Old 02-18-2012, 06:50 PM Thread Starter
good i was real nervous man....i reinstalled stock exhaust, installed 13T, and installed HID's. exhaust still sounds kinda crummy but a lot better. looked in the manual and read something about the use of low octane of gas causing the sounds, so im going to siphon the gas out tomorrow and replace it with new supreme
B09XX is offline
post #5 of 12 Old 02-18-2012, 06:53 PM
traitor08's Avatar
You can turn fuel off, invoking line to fuel pump( round thing in front of motor low in frame), and let gravity do the emptying for you. Don't forget to turn fuel on so it runs out.
MY RIDES
Amish washing the buggy^^^^
traitor08 is offline
post #6 of 12 Old 02-18-2012, 06:57 PM Thread Starter
that sound like a quicker solution, ill def try that
B09XX is offline
post #7 of 12 Old 02-18-2012, 09:40 PM
Are you going to get a programmer and re-install your fmf exhaust? I just picked up a power commander 5 for $279.95. from http://www.indysuperbike.com/
post #8 of 12 Old 02-19-2012, 06:27 AM Thread Starter
Yes....I have a pc3 from my street bike that I never installed. This will work right?
B09XX is offline
post #9 of 12 Old 02-19-2012, 06:41 AM Thread Starter
Nvm.....just looked it up
B09XX is offline
post #10 of 12 Old 02-19-2012, 03:22 PM
MizuriDirt's Avatar
The quick solution to your fuel problem would be some octane booster.
MizuriDirt is offline
