Stalled during hard braking? - Club700XX - Honda TRX700XX Forum
post #1 of 11 Old 02-22-2012, 07:43 PM Thread Starter
trx700xxry's Avatar
I just got my used/new trx700. Bought it from someone I knew who put 20-30 hours tops. When I was riding last weekend I was going pretty fast and then had to slam on the brakes for a truck coming through the trail. The engine stalled. I tried it again later and had it stall but while it was still rolling I let out the clutch and it started back up. Anyone have any problems like this? or was it the fuel injection building up/starving itself of fuel? Thanks for any input.
trx700xxry is offline
post #2 of 11 Old 02-22-2012, 07:49 PM
Did you have the clutch in when you slammed on the brakes?
post #3 of 11 Old 02-23-2012, 10:37 AM Thread Starter
trx700xxry's Avatar
Originally Posted by m_quick View Post
did you have the clutch in when you slammed on the brakes?
lol, yes!
post #4 of 11 Old 02-23-2012, 05:00 PM
I had the same problem with mine when I first bought it(bought it from the dealer still in the crate). It didn't do it very often but every now and then. Finally got around to the valve adjustment and after i adjusted the valves it has not did it since. I would try that if i were you, otherwise I would not worry about it to much.
Jakes700xx is offline
post #5 of 11 Old 02-23-2012, 09:39 PM
When you use the back brake press the clutch lever lol
727xx is offline
post #6 of 11 Old 02-24-2012, 06:05 AM Thread Starter
trx700xxry's Avatar
I know I'm the new guy but you guys give me no credit
post #7 of 11 Old 02-24-2012, 12:12 PM
GAZ69OK's Avatar
puke clutch
Pull in that clutch when you lock dem tars J/K
But seriously.... it probably has something to do with the flux capacitor.... Are you running 1.21gigawatts? If not, check the stator.
'08 TRX700XX List 'O Mods:
13t Drive
ASV Shorty Lever(s)
MQ Brake Block
Honda Racing Front Bumper
Alba Pro Elite Nerfs (Chrome)
J-n-J Full Skids
Uni Filter
CCP Steering Stabilizer
Streamline SS Brake Lines
Easton EXP M99 53/RM Mid Bars
MotoGrip Black Skulls
Offensive Fender Warning Tags
Black Shock Covers
FST Radiator Guard
Relocated Indicator Lights
Maier Top Cover
Tusk Gas Cap
GAZ69OK is offline
post #8 of 11 Old 02-24-2012, 04:15 PM
Not really messing with you cause your new. You just cant over look the obvious stuff. So we have to ask questions to rule stuff out some times. Not long ago someone posted about doing a oil change. And had over filled the quad cause they didn't know to drain the reservoir! I hope this wasn't you or you will think I'm messing with the new guy.
post #9 of 11 Old 02-24-2012, 06:23 PM
trx700xxry.
Several things you might consider.
1) Check to see if the clutch adjustment is too tight. (Note: Owner’s Manual is very clear on that adjustment) This could cause it to be somewhat engaged under just the right circumstances.
2) If the person that owned the machine before you used the wrong oil in the engine/wet clutch it may tend to cause the clutch to stick. If the oil is unknown to you, it might be worthwhile to replace it with the correct oil (Recommended in your Owner’s Manual. Some synthetics will cause problems) I use only Honda Oil (10W-40), however there are many good oils out there for these machines..
post #10 of 11 Old 02-25-2012, 02:58 PM Thread Starter
trx700xxry's Avatar
I understand, not too long ago I had a problem with my project truck not starting. I went and changed a few things to find out it was only a blown fuse. I appreciate all the help even if it does come with some messing around.
trx700xxry.
Thanks for the help. I knew the guy who owned it before. He did the initial break-in and then changed the oil. It has probably less than 30hrs on it. He still needs to give me the owners manual but I'll have to check the clutch adjustment. Today I went to the dealership and picked up an oil filter and honda oil.
