Piston clearance? - Club700XX - Honda TRX700XX Forum
post #1 of 3 Old 02-27-2012, 08:13 AM Thread Starter
valk680's Avatar
Piston clearance?
I have a 11:1 cp piston and want to do +1 valves on the intake. Do I need to cut the piston pockets a little more or is it set up for the +1 valves? I asked the machinest I know and he said I should take out as little as possible as or risk losing compression. If I do need to take more off can I just use a dremel to sand that .5 mil off?
715 11:1 big bore
+1 intake valves
Sredrums +3 throttle body
PCV
NGK BKR6EKPB-11 spark plug
K&N air filter w/outerwares,
Barker exhaust
PBI sprockets /D.I.D chain
Stage 3 Elka's on all 4 corners
valk680 is offline
post #2 of 3 Old 02-27-2012, 08:23 AM
boost addict's Avatar
You should be fine. I have ran 3 different cp pistons with +2 valves using the Webb 290 cam. I checked the piston to valve clearance on all 3 builds and it's never been a issue.
The best in the business
Bo White 205-886-7043
Ed @
Chris & Mike
boost addict is offline
post #3 of 3 Old 02-27-2012, 08:47 AM
they will fit from factory but its not a bad idea to cut the edge down a bit. On a fresh cylinder that piston rock is minimal you would probably never have an issue on a cylinder that gets wear the piston rock will increase. still you might never have an issue cp pockets are generally much bigger than other companies for bigger valves. its common to overlook piston rock into squish and valve measurments but it is important. on a pump gas motor i would rather have a little extra metal to metal room vs a little extra comp on a race motor its a little different.
EHSRACING is offline
