13t sprocket help - Club700XX - Honda TRX700XX Forum
post #1 of 16 Old 03-05-2012, 07:43 PM Thread Starter
700xxchris's Avatar
headscratch 13t sprocket help
ok i have read on here that a 13 tooth sprocket will help on trail rides to keep from having to clutch and feather the fuel how do i put one on and were can i get one and where is the oe sprocket i dont know what im doing till im told how to do something so if yall dont care help me out and give me some advise
700xxchris is offline
post #2 of 16 Old 03-05-2012, 07:56 PM
Tenn700xx's Avatar
https://www.club700xx.com/vb/showthread.php?t=2898
This should be the help you need.
Also I run a 12 tooth for riding in the woods and to me it's better than the 13.
2009 Honda 700XX se
12 tooth up front
Lexx pipe
Lexx programer
Uni filter
Air lid
Motowoz front shocks
Razr 2 front
Kutters rear.
Tenn700xx is offline
post #3 of 16 Old 03-05-2012, 10:16 PM
The 450r sprocket will fit, in case when you go to buy they don't know how to cross reference the part. It's the sprocket at the front part of the chain. Read above thread, but you don't need to tip quad or remove skid plate. A long extension and a swivel bolt will come off easy. If you want you can take off side cover, with 5mm allen and a 10mm socket. And just re-adjust chain when done. Sprocket cost like anywhere from $8.95 to $24.00. Once I put my big 3 on, I replaced my sprocket with oem 14t. And it will pull in 2nd gear with no throttle.
post #4 of 16 Old 03-05-2012, 11:40 PM Thread Starter
700xxchris's Avatar
what do i need to do to the chain take links out untill tight and also m quick were did u get your 6 pack rack
post #5 of 16 Old 03-06-2012, 05:18 AM
6 pack rack came from http://www.dgperf.com/index.asp
And chain is just an adjustment. Hard to see from this picture, but there's a big bolt on each side of the NASCAR sticker. All you do is losen it and use the adjuster's to tighten a click. Make sure both sides are the same when done, and re-tighten bolt easy job.
post #6 of 16 Old 03-06-2012, 05:26 AM
Here's a left side angle of bolt and adjuster. Silver ob-long thing with #'s on it, also known as the chain adjuster. Not the black frame bolts.
post #7 of 16 Old 03-06-2012, 10:05 AM
You can get a 13t sprocket from many online parts outlets. But, I'd recommend Rocky Mountain. Fronts sprockets for the trx450r that's '06 and newer fit fine... just make sure it's facing the right way... the teeth are slightly off center and one way, the front and rear sprocket will line up, the other way, they won't.
I have the big 3 as well, but decided to keep the 13t because I like the low speed torque and control for tight/technical riding. The draw back with the 13t is that you loose some top end... but not that much. Besides, how many time are you gonna need 85mph on a trail?
post #8 of 16 Old 03-07-2012, 04:07 PM Thread Starter
700xxchris's Avatar
im ordering the moose racing 13t sprocket this weekend ill take pics of the install for future member doing this mod i cant wait im ordering from the motorcycle super store they are great and you get your parts fast..
post #9 of 16 Old 03-07-2012, 04:42 PM
You will be amazed at the difference it makes. In my opinion the Trx should have came with the 13th from the factory.
post #10 of 16 Old 03-11-2012, 10:17 AM
Who makes the 12 tooth? Can't find one for the 450 or 700 from Renthal.
erider_jim is offline
