liquid sealant - Club700XX - Honda TRX700XX Forum
post #1 of 6 Old 03-18-2012, 02:04 PM Thread Starter
liquid sealant
Is there any difference between using that three bond stuff the manual recommends compared to the copper gasket maker stuff from autozone which i already have?
Its for sealing the cylinder head cover to the head. Thanks
fhibbs12 is offline
post #2 of 6 Old 03-18-2012, 06:49 PM
fhibbs12,
I'm not so sure about the copper gasket material from Autozone. I would recommend holding both materials and looking at the suggested usage on both items and especially the ingredients, temperature range, water resistance and so-on. Is this the valve cover or the barrel to the top of the engine? It is a little unclear to me. Also Is this a Honda or?? If it is a Honda I am almost certain that they use "O" rings not sealant. Not sure about the barrel to the top of the engine.
A little more info would be great.
post #3 of 6 Old 03-18-2012, 08:49 PM Thread Starter
The meeting between the cylinder head and tne cylinder head cover doesn't have a gasket. It uses a liquid sealant that forms a gasket.
Yes 08 xx
fhibbs12 is offline
post #4 of 6 Old 03-18-2012, 09:12 PM
fhibbs12,
Thanks.
post #5 of 6 Old 03-19-2012, 02:06 AM
1dmbhonkey's Avatar
I used permatex ultra gray ..... you cant find the threebond anywhere
1dmbhonkey is offline
post #6 of 6 Old 03-20-2012, 01:37 PM
I had a lotus and rebuilt the engine some years ago.. It all went together with liquid sealat.. The idea behind it is that there is zero tolerance, whereas a silicon gasket type instant gasket will always add some thickness and therefore not zero tolerance..
not the easiest stuff to find !
rappey is offline
