sprocket size vs hp ? - Club700XX - Honda TRX700XX Forum
post #1 of 7 Old 03-31-2012, 06:44 PM Thread Starter
Mid 50s hp is it still realistic to run a 13 tooth ? I put on an14 and thinking about dropping back down. All i do is tight technical shit and hill climbs....
Is it going to hurt anything?
fhibbs12 is offline
post #2 of 7 Old 03-31-2012, 08:04 PM
Depends on tire height too. But if all you are doing is tight trails I would think a 13 would work just fine
post #3 of 7 Old 03-31-2012, 08:37 PM Thread Starter
Kendas on stock rims.
No damage can be caused though if i did drop to a 13 though?
fhibbs12 is offline
post #4 of 7 Old 03-31-2012, 09:20 PM
allnew2me's Avatar
I just bought a 12t with stock rims and 22" kutters any problems with that setup?
allnew2me is offline
post #5 of 7 Old 04-01-2012, 04:19 PM
The motor tends to get too hot ,if it is constantly bouncing off the rev limiter, from my experience. If you are constantly on the clutch in the slow stuff with a 14t then change it to the 13t.
post #6 of 7 Old 04-01-2012, 10:07 PM
post #7 of 7 Old 04-04-2012, 09:30 PM
^X3 less clutch use in the technical stuff and it wakes up the acceleration when you need it. For me it seemed to climb alot easier aswell.
08 700XX
13T Front Sprocket
K&N High Flow
BKR6EKPB-11 (NGK 3452)
Reverse Rev Limiter Delete
Front Reciever
Moose Nerf Bars
Acerbis Hand Guards
Soon to come:
Rear Reciever
Front Bumper
Full Skid
Tires
Future Plans:
HMF Competition Series
PC5 Programmer
IMS Tank
PROJECT700 is offline
