727 back on the Dyno.... looking for more - Club700XX - Honda TRX700XX Forum
post #1 of 16 Old 04-18-2012, 11:57 PM Thread Starter
DL700's Avatar
Well since i bought Mikes (08700xx) Honda its time again to look for more power.,,,,I had it out last weekend and it ran great so i started off today with getting the most hp out of the bike and everything checked out and up to speed again
Here is where it currently sits
Things to do tomorrow:
Check to see if it has the cold heat range nitrous Spark plug in it still and install new plug for N/a
Play with timing
Swap camshafts to Custom grind
Maybe...lower the front down more and cut off some weight
DL700 is offline
post #2 of 16 Old 04-19-2012, 12:22 AM
Cant wait to see what u end up doing with this thing. We will have to go ride some time, if I ever get mine fixed.
08 Honda 700xx
Installed
Britalican is offline
post #3 of 16 Old 04-19-2012, 01:11 AM Thread Starter
DL700's Avatar
what is wrong with it? bring it by...
DL700 is offline
post #4 of 16 Old 04-19-2012, 04:34 AM
I need a new steering stem. I crashed a few months back and haven't had the time or money to work on it. Bent the steering stem and the tie rods. I replaced the tie rods, but i need to order a new stem still. I can get a stock stem for $199. idk yet.
08 Honda 700xx
Installed
post #5 of 16 Old 04-19-2012, 09:37 AM
Looks like she's running strong. Get some video of you racing it. I want to see it in action!
I'm going back to the dyno on Monday with a velocity filter and PCV.
post #6 of 16 Old 04-19-2012, 01:45 PM
08700xx's Avatar
I miss my XX already, I might have to buy another one and build a super duner whaen I have the money lol. Im glad you bought it DL so you can keep pushing forward on it, cant wait to see it finally make it into the 70s
(DL700)
Jody (Boost Addict)
08700xx is offline
post #7 of 16 Old 04-19-2012, 04:40 PM
boost addict's Avatar
That torque curve is sweet
The best in the business
Bo White 205-886-7043
Ed @
Chris & Mike
boost addict is offline
post #8 of 16 Old 04-19-2012, 06:53 PM Thread Starter
DL700's Avatar
Fought with it some more today.... 70 just isnt in it yet... though i did pick up 2+ in the overrev making for a longer powerband, but now running into valve float around 8400 rpm
DL700 is offline
post #9 of 16 Old 04-19-2012, 08:32 PM
Lookin good DL keep playin with it, it'll come around
post #10 of 16 Old 04-19-2012, 09:58 PM Thread Starter
DL700's Avatar
Dyno baseline from today and then the addition of the custom cam, Made some progress in the higher rpm's but to take advantage of the new cam we have to shim up the springs to eliminate valve float...currently @ 8500
DL700 is offline
