clutch adjusting - Club700XX - Honda TRX700XX Forum
post #1 of 6 Old 04-19-2012, 08:47 AM Thread Starter
clutch adjusting
just put a new clutch in from EHS, went for a ride lastnight and going slow making my own trail threw the woods i ended up with so much freeplay that the clutch wasnt disengaging all the way, tightened the cable up with the adjuster on the handlebar and 5min later it did the same thing, and then it seemed as though as it cooled down i kept getting less and less freeplay, i did put a 1.5 inch riser on a while ago and the cable is a little tight but this is the first time this has happened, have had a few rides with the riser and no issues. whats going on?
fraiolib is offline
post #2 of 6 Old 04-19-2012, 05:28 PM
did you try adjusting the cable at the clutch case side, or just on the handle bars? are you using the right kind of oil for a wet clutch?
08 Honda 700xx
Installed
Britalican is offline
post #3 of 6 Old 04-19-2012, 07:35 PM
Did you soak the clutch fibers in oil before you installed the clutch? And what kind of oil are you using?
post #4 of 6 Old 04-19-2012, 08:16 PM Thread Starter
im using maxima 10/40 ATV oil yes for wet clutches, and yes i soaked the plates in oil, i did adjust the cable on the motor which is on the mag side cover not the clutch cover,
fraiolib is offline
post #5 of 6 Old 04-19-2012, 08:27 PM
I just meant the engine side. my bad. does the ehs kit have a smaller plate like stock? did u put it in the right order. I'm guessing u did, but its my last idea. did u call ehs and ask them?
08 Honda 700xx
Installed
post #6 of 6 Old 04-19-2012, 08:36 PM Thread Starter
it was in the kit but his kit actually gets rid of the judder spring, i did get ahold of eric to make sure i put the plates in there correctly, you actually get rid of the smaller plate with this kit and just put all full size plates in
fraiolib is offline
