Fuel controller testing. - Club700XX - Honda TRX700XX Forum
post #1 of 18 Old 04-20-2012, 06:38 PM Thread Starter
estatic Fuel controller testing.
For the sake of the club members I'm doing some more testing. I'll be at the dyno on Monday with a few changes to my build. Originally I ran a dobeck fuel controller and UNI dual stage air filter with EHS lid(with side vents). This was intended to be a safe build for the trails. I wanted a good air filter with lots of protection. Well, I'm switching up to a Velocity air filter which I imagine would flow better than the UNI and I'm adding a Power Commander V. I'll show you real results comparing the dobeck to the PCV on the same dyno with the same tires and on the same machine. I'll post a dyno chart with a side by side comparison of the new set up vs the old. So far the UNI/Dobeck set has worked out great but there are a few rich spots I'd like to smooth out and I will accomplish this with the PCV. Here is a dyno chart comparing Valk680's build with PCV vs my build with dobeck. You'll see some areas where my power curve dips due to a rich a/f mixture. I'll post my findings and a dyno sheet monday. I ordered the velocity filter from Alba and they had excellent customer service. I ordered the PCV from 58cycle.com and their customer service was excellent as well!
post #2 of 18 Old 04-20-2012, 10:31 PM
XxX700XxX's Avatar
cant wait to see the results!!
2009 700xx
1989 yamaha banshee
not stock
80hp
XxX700XxX is offline
post #3 of 18 Old 04-20-2012, 10:48 PM
DL700's Avatar
your Partial throttle runs will be the most impressive and off idle adjustability
DL700 is offline
post #4 of 18 Old 04-21-2012, 12:41 AM Thread Starter
Yea, it was pretty cool to watch them dial in Valk's BB set up. My XX has been running just fine but I want this build to see its full potential. A better flowing air filter and a fine tune should do it. I'll post results in a few days. Dyno appointment is at 10am Monday and I'll bring my laptop so I can post results asap.
post #5 of 18 Old 04-21-2012, 09:55 AM
I just put the velocity kit on my xx. Ive heard its common for the metal piece in the cone to fall threw and get sucked into the throttle body. So is the dobeck controller the same as the ehs controller?
fraiolib is offline
post #6 of 18 Old 04-21-2012, 10:50 AM Thread Starter
Yes, dobeck is the ehs fuel controller. I think alba sent me the wrong filter. The box was labeled trx 450 and i do not have an aluminum adapter. The adapter it came with is not fitting right.
post #7 of 18 Old 04-21-2012, 11:16 AM
No its right. Theyre the same as the 450. Its a plastic adapter and it fits tight
fraiolib is offline
post #8 of 18 Old 04-21-2012, 11:20 AM Thread Starter
Alright, good deal. I appreciate the info! Its on pretty tight so it should be good. Cant wait to dial her in.
post #9 of 18 Old 04-21-2012, 11:44 AM
On the dyno chart which is yours and which is valk680s?
fraiolib is offline
post #10 of 18 Old 04-21-2012, 11:56 AM Thread Starter
Valk is the 53hp build and i have the 57hp build. There is a thread with lots of dyno charts and explanations of our individual builds
https://www.club700xx.com/vb/showthread.php?t=7773
