Page 1 of 2 | 1 | 2 |
Cam Question
If I'm going to have a valve adjustment done by a buddy, would now be the time to drop in a new cam? I was thinking HC3 (I have exhaust and Programmer).
08 TRX 700XX
HMF Full Performance Exhaust
EHS Programmer
11/16 L8ton Swaybar
Skat~Trak Haulers 20X10X10
Alba Pro Elite Nerfs
Trail Tech Vapor Speedo/odom
Sponsored Links | |||
Now would be the time, but I would get a web if you have the extra dough
Guess the question is how much more is the web.
08 TRX 700XX
EHS Programmer
11/16 L8ton Swaybar
Bout 100 extra bucks and you will also need the hard welded rockers
a lot more. u can get a new hot cam for about $150, and its drop in. If you get a web cam you are going to pay more that $200 for it, plus hardened rockers ($150ish), and and springs($160ish, plus $40 for new valve seals). the set up will be about $550 or more, unless you find some really good deals.
08 Honda 700xx
Installed
So is the extra money really worth the gain in power? I'm not trying to go crazy with my build and after the cam I think i'm done with internals.
08 TRX 700XX
EHS Programmer
11/16 L8ton Swaybar
If you are not going any further in the build then you will not see the full potential of the web camshaft
Don't get me wrong, if I had a ton of money I would be all about going further, but current and future finances say this will be the last internal mod before I go into the suspension.
08 TRX 700XX
EHS Programmer
11/16 L8ton Swaybar
That's understandable but you'll be better off with the hotcam if this is it for the motor
Cool, thats what I needed to know, thanks for the info.
08 TRX 700XX
EHS Programmer
11/16 L8ton Swaybar
Sponsored Links | |
Thread Tools | |
Display Modes | |
Posting Rules | |
